17268 Discussions
Hello, I've been having problem with Quartus.
Icetome
I've been trying to run a Wavelength Simulation using Quartus 22.1 and Model Sim 20.1. Every time I try to run the simulation, I get an error message.
# ** Error: Lab0.vho(30): (vcom-1598) Library "fiftyfivenm" not found.
# ** Error: Lab0.vho(32): (vcom-1136) Unknown identifier "FIFTYFIVENM".
# -- Loading package TEXTIO
# -- Loading package std_logic_1164
# ** Note: Lab0.vho(35): VHDL Compiler exiting
I've tried reinstalling the software, but that hasn't worked, and I really need this for my classwork. Is there any way to fix this?
SyafieqS
Hi Kevin,
There is previous post similar to your issue,
You may take a look at the thread and see if the suggestion is applicable.
SyafieqS
May I know if there is any update?
SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
