17268 Discussions
Hello world program hangs :(
I have generated the binary file of the hello world program. I have used the host program to launch it. However, it never completes. It gets stuck at the line
status = clFinish(queue);
Here is my output of the program.
manoj@EV-PHD-ROS-PC:~/Documents/exm_opencl_hello_world_x64_linux/hello_world/bin$ ./host
Querying platform for info:
CL_PLATFORM_NAME = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR = Intel(R) Corporation
CL_PLATFORM_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 17.1.2
Querying device for info:
CL_DEVICE_NAME = a10gx : Arria 10 Reference Platform (acla10_ref0)
CL_DEVICE_VENDOR = Intel(R) Corporation
CL_DEVICE_VENDOR_ID = 4466
CL_DEVICE_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 17.1.2
CL_DRIVER_VERSION = 17.1
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0
CL_DEVICE_GLOBAL_MEM_SIZE = 2147483648
CL_DEVICE_IMAGE_SUPPORT = true
CL_DEVICE_LOCAL_MEM_SIZE = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000
CL_DEVICE_MAX_COMPUTE_UNITS = 1
CL_DEVICE_MAX_CONSTANT_ARGS = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 536870912
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0
Command queue out of order? = false
Command queue profiling enabled? = true
Using AOCX: hello_world.aocx
Reprogramming device [0] with handle 1
MMD INFO : Autodetect Cable not found!!
MMD INFO : setting Cable to default value 1
MMD INFO : setting Device Index to default value 1
MMD INFO : executing "quartus_pgm -c 1 -m jtag -o "P;reprogram_temp.sof@1""
Info: *******************************************************************
Info: Running Quartus Prime Programmer
Info: Version 17.1.2 Build 304 01/31/2018 SJ Pro Edition
Info: Copyright (C) 2018 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Fri May 18 11:38:58 2018
Info: Command: quartus_pgm -c 1 -m jtag -o P;reprogram_temp.sof@1
Info (213045): Using programming cable "USB-BlasterII [3-3]"
Info (213011): Using programming file reprogram_temp.sof with checksum 0x308535CE for device 10AX115S2F45@1
Info (209060): Started Programmer operation at Fri May 18 11:39:05 2018
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x02E060DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Fri May 18 11:39:20 2018
Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 1685 megabytes
Info: Processing ended: Fri May 18 11:39:20 2018
Info: Elapsed time: 00:00:22
Info: Total CPU time (on all processors): 00:00:11
Kernel initialization is complete.
Launching the kernel...
and never completes. I see that the kernel is launched. But it waits for the events to get completed.
And whenever I use aocl program command I get
For some reason PCIe is not being used to program. When I cancel and quit the session, I have to kill the jtagd, and use quartus_pgm -a in order to reprogram. Otherwise I get
Error (213013): Programming hardware cable not detected
Why? Am I doing something wrong. Is this because of PCIe connection? I have checked lspci | grep Altera and everything seems to be alright!
lspci | grep Altera
03:00.0 Processing accelerators: Altera Corporation Device 2494 (rev 01)
Manoj.
RVija
Dear Manoj,
We are now facing the same issue. In case you have resolved it, Kindly let us know how you resolved it.
Thank you.
