I am try to build and test a very large adder, as my previous try have meet the quartus software constraints, my new way to do that is this: I write a basic logic for full adder, than a 4 bit adder consist 4FAs, and a large adder consist 500 4 bit adders. Here are the code: For FA: library ieee; use ieee.std_logic_1164.all; entity FA is port(a, b : in std_logic; cin : in std_logic; cout : out std_logic; sum : out std_logic); end entity FA; architecture df_FA of FA is begin cout <= (a AND b) OR (cin AND (a OR b)); sum <= a xor b xor cin; end architecture df_FA; For 4 bit adder: library ieee; use ieee.std_logic_1164.all; entity RCA is port( a, b : in std_logic_vector(3 downto 0); cout : out std_logic; cin : in std_logic; sum : out std_logic_vector(3 downto 0) ); end entity RCA; architecture struct_RCA of RCA is component FA is port( a, b : in std_logic; cin : in std_logic; cout : out std_logic; sum : out std_logic); end component; signal carry: std_logic_vector(3 downto 0); begin RippleCarryAdder: for i in 0 to 3 generate FAs: entity work.FA PORT MAP ( a=>a(i), b=>b(i), cin=>cin, cout=>carry(i), sum=>sum(i) ); End generate; cout<=carry(3); end architecture struct_RCA; For large adder: library IEEE; use IEEE.STD_LOGIC_1164.ALL; USE IEEE.numeric_std.ALL; entity CA is generic ( nblocks: integer := 500; vsize : integer := 2000 ); Port ( a, b : in STD_LOGIC_VECTOR(vsize-1 downto 0); sum : out std_logic_vector(vsize - 1 downto 0) ); end entity CA; architecture Behavioral of CA is signal carry : STD_LOGIC_VECTOR(nblocks downto 0); begin carry(0)<='0'; adders : for i in 1 to nblocks generate adder : entity work.RCA port map( cin => carry(i-1), a => a(4*i-1 downto 4*(i-1)), b => b(4*i-1 downto 4*(i-1)), sum => sum(4*i-1 downto 4*(i-1)), cout => carry(i) ); end generate; end architecture Behavioral; I haven't finish the clock and shift input part, and the code so far pass the compile and synthesis. However when I try do to compliation in quartus, a error "Error: Can't place 6000 pins with 2.5 V I/O standard because Fitter has only 342 such free pins available for general purpose I/O placement" poped up. and compliation stopped. And also in the summary, it said ony 29xx logic element have used, one of my contril signal(a,b or sum) have 500*4=2000bits long, three of them should have 6000 logic elements at least, why is that? Is that becasuse of I haven't finish the shift input part? Thank you all very much!Link Copied
In your top level you have asked for 6000 pins. I don't know of any fpga having this resource of pins.
Pins do not require LUTs but logic does. Anyway you are targetting an adder of two inputs 2000 bits wide. This is far too wide and will cover range 0 to 2^2000 which is is astronomically high.
