Help about altfp_exp
Hi All
I want to insert altfp_exp megacore function to my block diagram. However, I have a problem. when I try to insert altfp_exp megafunction, a message such "loading megawizard" is visible in the screen, and the megawizard has not started. May anyone send me a simple design example with .bsf files.
here's an altfp_exp with default parameters generated for CIII in QII 9.1sp2.
you might look into reinstalling or otherwise debugging your original issue
Thank you very much. I reinstalled my quartus II 9.1 and then I installed the Sp2. But the problem has not been solved yet.
I have a same problem.. thank you so much for your shared but I need this block and files with clk_en .... may you add this file here.. please..
here is the same exact block with a CE
thank you... ı am using 9.1sp2... I dont understand why dont open megawizard of exp...
I have the same problem. Is there anyone who solved this problem ?
