17261 Discussions
Help in converting pin assignment on CYCLONE II to CYCLONE IV
hi,
i have a problem when i try to set up the pin assignment in my project in cyclone IV E EP4CE115F29C7
this is my pin assignment in cyclone II EP2C35F672C6:
. https://www.alteraforum.com/forum/attachment.php?attachmentid=8043
then i convert to cyclone IV E EP4CE115F29C7.
https://www.alteraforum.com/forum/attachment.php?attachmentid=8044 it doesn't work.
Please help. Thanks
It would probably be easier to use the pin planner rather than the assignment editor, you will see more easily if you are using valid pins or not.
