17264 讨论
Help with Finite state machine
名誉分销商 II
3,181 次查看
Hi guys, as an altera pupil i am still struggling with getting FSM to work properly i wonder if it is my testbench that has a problem or the code itself. This is the idea:
when key_0 is pressed let LEDG(1) light (on) ----closed state
when key_1 is pressed let LEDG(0) light (on)-----opened state
when key_2 is pressed let LEDR(1) light (on)------locked state
when key_3 is pressed it unlocks and enters into error state causing LEDG(1), LEDG(0), LEDR(0) and LEDR(1) to light(all on)
This is how my code looks at the moment
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity uppgift_dorr is
port( clk : in std_logic; --clock signal
reset_n : in std_logic; --reset signal
key_0, key_1, key_2, key_3 : in std_logic;
LEDR : out std_logic_vector(1 downto 0);
LEDG : out std_logic_vector(1 downto 0)
end uppgift_dorr;
architecture Behavioral of uppgift_dorr is
--Defines the type for states in the state machine
type state_type is (closed,opened,locked,error);
--Declare the signal with the corresponding state type.
signal Current_State, Next_State : state_type;
begin
-- Synchronous Process
p0: process(clk, reset_n)
begin
if( reset_n = '0' ) then --Synchronous Reset
Current_State <= opened;
elsif (rising_edge(clk)) then --Rising edge of Clock
Current_State <= Next_State;
end if;
end process;
-- Combinational Process
p1: Process(Current_State, key_0, key_1, key_2, key_3)
begin
case Current_State is
when opened =>
LEDG <= "01"; LEDR <= "00";
if ( key_0 = '0' ) then
Next_State <= closed;
else
Next_State <= opened;
end if;
when closed =>
LEDG <= "10"; LEDR <= "01";
if ( key_1 = '0') then
elsif (key_2 = '0') then
Next_State <= locked;
else
end if;
when locked =>
LEDG <= "00"; LEDR <= "10";
if ( key_3 = '0') then -- Låser upp dörren
elsif(key_2 = '0')then -- tray to lock, error
Next_State <= error;
else
end if;
when error =>
LEDG <= "11"; LEDR <= "11";
end case;
--end if;
end process;
end Behavioral;
The test bench looks this way:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY uppgift_dorr_vhd_tst IS
END uppgift_dorr_vhd_tst;
ARCHITECTURE uppgift_dorr_arch OF uppgift_dorr_vhd_tst IS
-- constants
-- signals
SIGNAL clk : STD_LOGIC := '0';
SIGNAL key_0 : STD_LOGIC;
SIGNAL key_1 : STD_LOGIC;
SIGNAL key_2 : STD_LOGIC;
SIGNAL key_3 : STD_LOGIC;
SIGNAL LEDG : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL LEDR : STD_LOGIC_VECTOR(1 DOWNTO 0);
SIGNAL reset_n : STD_LOGIC := '0';
COMPONENT uppgift_dorr
PORT (
clk : IN STD_LOGIC;
key_0 : IN STD_LOGIC;
key_1 : IN STD_LOGIC;
key_2 : IN STD_LOGIC;
key_3 : IN STD_LOGIC;
LEDG : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
LEDR : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
reset_n : IN STD_LOGIC
END COMPONENT;
BEGIN
i1 : uppgift_dorr
PORT MAP (
-- list connections between master ports and signals
clk => clk,
key_0 => key_0,
key_1 => key_1,
key_2 => key_2,
key_3 => key_3,
LEDG => LEDG,
LEDR => LEDR,
reset_n => reset_n
clk <= NOT clk after 20 ns; -- 50MHz
reset_n <= '0', '1' after 100 ns;
init : PROCESS
-- variable declarations
BEGIN
key_0 <= '1';
WAIT FOR 50 ns;
key_1 <= '1';
WAIT FOR 50 ns;
key_2 <= '1';
WAIT FOR 50 ns;
key_3 <= '1';
WAIT FOR 50 ns;
key_0 <= '0';
WAIT FOR 50 ns;
key_1 <= '0';
WAIT FOR 50 ns;
key_2 <= '0';
WAIT FOR 50 ns;
key_3 <= '0';
WAIT FOR 50 ns;
WAIT;
END PROCESS init;
always : PROCESS
-- optional sensitivity list
BEGIN
-- code executes for every event on sensitivity list
WAIT;
END PROCESS always;
END uppgift_dorr_arch;
Can anyone help?
0 项奖励
25 回复数
名誉分销商 II
1,979 次查看
If it doesnt work, you need to debug it. Thats what the testbench is for. Does the state machine go through all states as expected? have you studied the waveforms.
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
What is strange about the wave form is that i do not see the value 11 in the section LEDR and LEDG probably some state is missing. This is what i have difficulty to figure out. Help please?
0 项奖励
名誉分销商 II
1,979 次查看
You need to trace back the problem. You can show all the states on the waveform. Have you added all the signals from the unit under test?
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
Yes i have done so i have added all the unit under test. I am trying to see how i can figure out the problem, Ooops!!!
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
your code looks ok to me but your testbench does not cover well your state transitions.
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
Hi again i have added the transition states but i still do not have all the states showing up. 00, 01, 10, 11 where could the problem be? Help please!!
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
try one of these two patterns.
init : PROCESS BEGIN wait for 100 ns; key_0 <= '1'; WAIT FOR 500 ns; key_0 <= '0'; wait for 300 ns; key_1 <= '1'; WAIT FOR 600 ns; key_1 <= '0'; wait for 200 ns; key_2 <= '1'; WAIT FOR 850 ns; key_2 <= '0'; wait for 200 ns; key_3 <= '1'; END PROCESS init;
or
init : PROCESS(reset_n,clk) variable shift_reg : std_logic_vector(19 downto 0); BEGIN if reset_n = '0' then shift_reg := x"01000"; elsif rising_edge(clk) then shift_reg(0) := shift_reg(19) xor shift_reg(16); shift_reg(19 downto 1) := shift_reg(18 downto 0); key_0 <= shift_reg(0) or shift_reg(1) or shift_reg(2); key_1 <= shift_reg(4) or shift_reg(7) or shift_reg(9); key_2 <= shift_reg(2) or shift_reg(10) or shift_reg(12); key_3 <= shift_reg(13) or shift_reg(11) or shift_reg(19); end if; END PROCESS init;
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
or
--- Quote End ---
Hi Kaz, thank you once again for the code i have been able to have all the states appearing now but the problem is that it does not work effectively on the DE2-115. The LEDG and LEDR are coming on at the same time. I will like it to work as i stated in my initial help question:
https://www.alteraforum.com/forum/attachment.php?attachmentid=8266
0 项奖励
名誉分销商 II
1,979 次查看
I am not surprised that it doesn't seem to work in hardware since you depend on manual switching.
manual switching is too slow and leads to rebounce thus when you press any switch it will go through 0/1 for sometime until it settles.
The remedy is to add switch debounce logic.
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
Wow Kaz you are genius, thank you for the help i will try to read about switch debounce logic and see how it can be added to the code, since i am just a beginner in vhdl and using of the Altera DE2-115 hardware. Once more i am grateful
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
I am no expert on debouncing logic. some boards have it as part of switch design outside fpga. but you can try this(not tested)
per each switch
signal count_0 : unsigned(17 downto 0) := (others => '0'); signal sw_0_d, sw_0_final : std_logic; --in a clocked process sw_0_d <= sw_0; if sw_0 = sw_0_d then count_0 <= count_0 +1; else count_0 <= (others => '0'); end if; if count_0 > 250000 then -- about 5 msec bounce time sw_0_final <= sw_0; end if;
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
per each switch
--- Quote End ---
Sorry to bother you guys again , Kaz, i am having difficulties to cause the code to function without errors, please where exactly in the clock process or per each switch in my code should i insert the code your posted. Thanks for helping
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
use a separate clocked process per each key then in your state machine use sw_0_final,sw_1_final,...etc instead of sw_0,sw_1 ...etc.
declare 3 counters and other signals at top of your design.
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
please Kaz, i really do not understand how to go about this as i am a beginner in VHDL. Please do you mind showing me an example with reference to my code above. The 3 counters how is that going to be done and other signals?
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
here is the code. Note it will fail your simulation unless you change the pattern of keys to let counter reach 25000 clocks so it is suitable for hardware mostly.
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.numeric_std.ALL; entity uppgift_dorr is port( clk : in std_logic; --clock signal reset_n : in std_logic; --reset signal key_0, key_1, key_2, key_3 : in std_logic; LEDR : out std_logic_vector(1 downto 0); LEDG : out std_logic_vector(1 downto 0) ); end uppgift_dorr; architecture Behavioral of uppgift_dorr is --Defines the type for states in the state machine type state_type is (closed,opened,locked,error); --Declare the signal with the corresponding state type. signal Current_State, Next_State : state_type; signal count_0 : unsigned(17 downto 0) := (others => '0'); signal count_1 : unsigned(17 downto 0) := (others => '0'); signal count_2 : unsigned(17 downto 0) := (others => '0'); signal count_3 : unsigned(17 downto 0) := (others => '0'); signal key_0_d,key_0_final: std_logic; signal key_1_d,key_1_final: std_logic; signal key_2_d,key_2_final: std_logic; signal key_3_d,key_3_final: std_logic; begin --debounce process begin wait until clk = '1'; key_0_d <= key_0; if key_0 = key_0_d then count_0 <= count_0 +1; else count_0 <= (others => '0'); end if; if count_0 > 250000 then -- about 5 msec bounce time key_0_final <= key_0; end if; key_1_d <= key_1; if key_1 = key_1_d then count_1 <= count_1 +1; else count_1 <= (others => '0'); end if; if count_1 > 250000 then -- about 5 msec bounce time key_1_final <= key_1; end if; key_2_d <= key_2; if key_2 = key_2_d then count_2 <= count_2 +1; else count_2 <= (others => '0'); end if; if count_2 > 250000 then -- about 5 msec bounce time key_2_final <= key_2; end if; key_3_d <= key_3; if key_3 = key_3_d then count_3 <= count_3 +1; else count_3 <= (others => '0'); end if; if count_3 > 250000 then -- about 5 msec bounce time key_3_final <= key_3; end if; end process; -- Synchronous Process p0: process(clk, reset_n) begin if( reset_n = '0' ) then --Synchronous Reset Current_State <= opened; elsif (rising_edge(clk)) then --Rising edge of Clock Current_State <= Next_State; end if; end process; ----------------------------------------------------------------------------- -- Combinational Process p1: Process(Current_State, key_0_final, key_1_final, key_2_final, key_3_final) begin case Current_State is when opened => LEDG <= "01"; LEDR <= "00"; if ( key_0_final = '0' ) then Next_State <= closed; end if; when closed => LEDG <= "10"; LEDR <= "01"; if ( key_1_final = '0') then Next_State <= opened; elsif (key_2_final = '0') then Next_State <= locked; end if; when locked => LEDG <= "00"; LEDR <= "10"; if ( key_3_final = '0') then -- Låser upp dörren Next_State <= closed; elsif(key_2_final = '0')then -- tray to lock, error Next_State <= error; end if; when error => LEDG <= "11"; LEDR <= "11"; end case; end process; end Behavioral;
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
Hi Kaz, i lack words to show my appreciation thank you so much for the help i am going to test it on the DE2 board.
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
Hi Kaz, i have an error message in accordance with the code: what could be the reason? i have added an end at the end of the process but it still did not help
vhdl gurus you are also free to give a helping hand, thanks
Error (10500): VHDL syntax error at uppgift_dorr.vhd(92) near text "begin"; expecting "end", or "(", or an identifier ("begin" is a reserved keyword), or a concurrent statement
0 项奖励
名誉分销商 II
1,979 次查看
Which code are you referring to. The code posted by Kaz compiles just fine. Have you tried to modify it?
0 项奖励
名誉分销商 II
1,979 次查看
--- Quote Start ---
--- Quote End ---
No i have done no modifications to it, you can see below:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; entity uppgift_dorr is port( clk : in std_logic; --clock signal reset_n : in std_logic; --reset signal key_0, key_1, key_2, key_3 : in std_logic; LEDR : out std_logic_vector(1 downto 0); LEDG : out std_logic_vector(1 downto 0) ); end uppgift_dorr; architecture Behavioral of uppgift_dorr is --Defines the type for states in the state machine type state_type is (closed,opened,locked,error); --Declare the signal with the corresponding state type. signal Current_State, Next_State : state_type; --Additional signals to work with the debounce process signal count_0 : unsigned(17 downto 0) := (others => '0'); signal count_1 : unsigned(17 downto 0) := (others => '0'); signal count_2 : unsigned(17 downto 0) := (others => '0'); signal count_3 : unsigned(17 downto 0) := (others => '0'); signal key_0_d,key_0_final: std_logic; signal key_1_d,key_1_final: std_logic; signal key_2_d,key_2_final: std_logic; signal key_3_d,key_3_final: std_logic; --Debounce process begin --debounce process(clk) begin wait until clk = '1'; key_0_d <= key_0; if key_0 = key_0_d then count_0 <= count_0 +1; else count_0 <= (others => '0'); end if; if count_0 > 250000 then -- about 5 msec bounce time key_0_final <= key_0; end if; key_1_d <= key_1; if key_1 = key_1_d then count_1 <= count_1 +1; else count_1 <= (others => '0'); end if; if count_1 > 250000 then -- about 5 msec bounce time key_1_final <= key_1; end if; key_2_d <= key_2; if key_2 = key_2_d then count_2 <= count_2 +1; else count_2 <= (others => '0'); end if; if count_2 > 250000 then -- about 5 msec bounce time key_2_final <= key_2; end if; key_3_d <= key_3; if key_3 = key_3_d then count_3 <= count_3 +1; else count_3 <= (others => '0'); end if; if count_3 > 250000 then -- about 5 msec bounce time key_3_final <= key_3; end if; end process; -------------- begin -- Synchronous Process p0: process(clk, reset_n) begin if( reset_n = '0' ) then --Synchronous Reset Current_State <= opened; elsif (rising_edge(clk)) then --Rising edge of Clock Current_State <= Next_State; end if; end process; ----------------------------------------------------------------------------- -- Combinational Process p1: Process(Current_State, key_0_final, key_1_final, key_2_final, key_3_final) begin case Current_State is when opened => LEDG <= "01"; LEDR <= "00"; if ( key_0_final = '0' ) then Next_State <= closed; --else -- Next_State <= opened; end if; when closed => LEDG <= "10"; LEDR <= "01"; if ( key_1_final = '0') then Next_State <= opened; elsif (key_2_final = '0') then Next_State <= locked; --recent change it was key_2 locked else Next_State <= closed; ---here was closed end if; when locked => LEDG <= "00"; LEDR <= "10"; if ( key_3_final = '0') then -- Låser upp dörren Next_State <= locked; elsif(key_2_final = '0')then -- tray to lock, error Next_State <= error; else Next_State <= closed; end if; LEDR <= "00"; when error => LEDG <= "11"; LEDR <= "11"; Next_State <= error; end case; end process; end Behavioral;
0 项奖励
名誉分销商 II
1,908 次查看
But somehow you have misscopied it (or modified it)
There is an extra "begin" on line 97, and the first debounce process has (clk) as a sensitivity list when it should have no sensitivity list. Otherwise the code is the same.
It also contains extra comments that Kaz's doesnt have either.
I suspect you didnt copy it - you tried to merge it into your own copy.
0 项奖励
回复
