Help with Shifting !
Hi everyone,
I am trying to write a vhdl program that takes a input R and a shifted version of it and adds them, then adds the result to a 2nd shifted version of R and then AND's it with a mask. (basically calculating the mod).
Here is the code i have so far but i am not sure how to append Cout to the input of my AND so that i make sure to and S+Cout AND Mask :
PORT
R : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
MASK : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
OutRem : OUT STD_LOGIC_VECTOR(31 DOWNTO 0)
END g18_lab2_RNG;
ARCHITECTURE bdf_type OF g18_lab2_RNG IS
COMPONENT g18_lab2
PORT(A : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
B : IN STD_LOGIC_VECTOR(31 DOWNTO 0);
Cin : IN STD_LOGIC;
S : OUT STD_LOGIC_VECTOR(31 DOWNTO 0);
Cout : OUT STD_LOGIC
END COMPONENT;
SIGNAL SYNTHESIZED_WIRE_0 : STD_LOGIC;
SIGNAL SYNTHESIZED_WIRE_1 : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL SYNTHESIZED_WIRE_2 : STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL RShift1: STD_LOGIC_VECTOR(31 DOWNTO 0);
SIGNAL RShift2: STD_LOGIC_VECTOR(31 DOWNTO 0);
BEGIN
RShift1 <= STD_LOGIC_VECTOR(unsigned(R)sll 1);
RShift2 <= STD_LOGIC_VECTOR(unsigned(R)sll 16);
b2v_inst : g18_lab2
PORT MAP(A => R,
B => RShift1,
Cin => '0',
S => SYNTHESIZED_WIRE_1,
Cout => SYNTHESIZED_WIRE_0);
b2v_inst2 : g18_lab2
PORT MAP(A => RShift2,
B => SYNTHESIZED_WIRE_1,
Cin => SYNTHESIZED_WIRE_0,
S => SYNTHESIZED_WIRE_2,
Cout => ;
OutRem <= SYNTHESIZED_WIRE_2 AND MASK;
END bdf_type;
EDIT: i figured out i can use & to concatenate bits so i changed my Cout to : Cout => SYNTHESIZED_WIRE_3
and then : OutRem <= SYNTHESIZED_WIRE_3 & SYNTHESIZED_WIRE_2 AND MASK;
Are you aware of the 'mod' operator in VHDL?
Have a look at:
http://stackoverflow.com/questions/25848879/difference-between-mod-and-rem-operators-in-vhdl
then have a play with the operator. I think it'll allow you to clean up your code a little... or maybe quite a bit.
Cheers,
Alex
