17267 Discussions
JBCC to generate the uncompressed JBC file
I use the Quartus || version13.0 (Need support MAX 3000A series) and trying to generate the JBC file(Uncompressed), from the Altera website, mentioned the quartus_jbcc.exe can generate the uncompressed jbc file(Since Quartus || version13.0 only can generate the compressed jbc file ), I tried the quartus_jbcc.exe, but the result is that it generated the same jbc file with compressed, how could I generate the uncompressed jbc file with Quartus || version13.0 ?:confused:
Have you seen this?
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03192009_674.html
Is that how you used the quartus_jbcc.exe executable?
Cheers,
Alex
