Help with design
Hi I need help to set up a divider circuit. I'm try to create a circuit to divide a 10 bit binary number by a 6 bit binary number. I've thought of using shift registers and a subtracter? :confused: Any help will be greatly appreciated! thank you :rolleyes:
Try the lpm_divide megafunction. You can select and configure it with the MegaWizard available on the Tools menu.
