17268 Discussions
Help with reseting counet
Hey, I've written a simple counter code
When the cnt = 5 the
signal std_logic_vector Inc +'1'
Now I want you end this process when
It's equal to "1111";
Everytime I try to end this I see In the waveform simulation the it just beginning from" 0000" again.
What can I do?
Why not post the code and be a more descriptive of the problem.
Entity VCO is
Port(sw:in std_logic;
Clk:in std_logic;
Bit_4: out std_logic_vectot(3 downto 0));
End entity;
Architecture behave of VCO is
Signal cnt: integer range 0 to 50000000:=0;
Signal f_out: std_logic_vector(3 downto 0):=x"0";
Begin
Process (clk)
Begin
If sw = '1' then
If clk 'event and clk=' 1' then
Cnt<=cnt+1;
If cnt=5 then
F_Out<=f_out+'1';
Cnt<=0;
Elsif cnt=5 then
If f_out="1111" then
F_out<="1111"
Cnt<=0;
End if;
End if;
End if;
Elsif ='0' then
Cnt<=0;
F_out<="ZZZZ";
End if;
End process;
Bit_4<=f_out;
End;
I want when f_out="1111"
The counter will stop end remain on "1111"
Instead of looping end start counting from 0000 again
What is F_F_out - it's not declared in your code.
Assuming this is a typo - then your code will never have f_out locked at "1111" because the only situation where you check for "1111" also resets cnt.
maybe you need the
if f_out = "1111" then
To have the highest prirotiy.
On a side note - why have you got the sw signal as an asynchronous enable? this is bad practice - it should be a synchronous enable.
I've tried this it didn't work..
It shows me in the simulation the same thing
And I don't have sw signal
It is a toggle sw for on/off use
Tried what? I dont see any new code.
Have you tried this:
Process (clk) Begin If clk 'event and clk=' 1' then Cnt<=cnt+1; if f_out /= "1111" then If cnt=5 then F_Out<=f_out+'1'; Cnt<=0; Elsif cnt=5 then If f_out="1111" then F_F_out<="1111" Cnt<=0; End if; End if; end if; End if; End process;
--- Quote Start ---
--- Quote End ---
Thanks man! It worked
I don't know how I didn't think about "/=" inequality
