17255 Discussions
Help with verilog testbench code
Am trying to solve a parking slot problem where an individual has 4 parking spaces outside of his/her apartment complex. this individual wants to know when two adjacent spaces are open as he/she does not want anyone to park next to their car. (normally, this person parks at the end of a large parking lot to avoid any scrapes or scratches). this individual proceeds to set up pressure switches in the parking spaces and has a logic indicator in their apartment building. they want one logic indicator to activate if two adjacent spaces become open, another logic indicator to activate if three adjacent spaces become open, a third if all spaces are open and a fourth if one space is open (in case they choose to risk it).
i am having problems with the testbench. it doesn't generate the desired output waves when i run it in modelsim. any help would be appreciated.
testbench
module parking_lot_tb;
wire p1 = 1'b0;
wire p2 = 1'b0;
wire p3 = 1'b0;
wire p4 = 1'b0;
wire a1;
wire a2;
wire a3;
wire a4;
reg clk;
parking_lot dut(
p1,
p2,
p3,
p4,
a1,
a2,
a3,
a4
initial begin
clk = 1;
end
always begin
assign# 100 p1 = ~( p1);
assign# 200 p2 = ~( p2);
assign# 300 p3 = ~( p3);
assign# 400 p4 = ~( p4);
end
initial
$monitor($stime,,clk,,a1,,a2,,a3,,a4,,);
endmodule
Main code:
module parking_lot(
p1,
p2,
p3,
p4,
a1,
a2,
a3,
a4
input p1;
input p2;
input p3;
input p4;
output a1;
output a2;
output a3;
output a4;
assign a1 = ( ( ( p1 | p2 ) | p3 ) | p4 );
assign a2 = ( ( ( p1 & p2 ) | ( p2 & p3 ) ) | ( p3 & p4 ) );
assign a3 = ( ( ( ( p1 & p2 ) & p3 ) & ~( p4) ) | ( ( p2 & p3 ) & p4 ) );
assign a4 = ( ( ( p1 & p2 ) & p3 ) & p4 );
endmodule
I suggest you generate a 4-bit, registered, counter that generates the 16 different combinations of slot availability possible. Connect each bit of the counter to your p1-p4 module input signals.
There are several ways in which you could generate this stimulus - I'm not sure yours is one of them :oops:
You might try this:
module tb ();
reg [3:0] p;
integer i;
initial
begin
p = 0;
for (i=0; i<=15; i=i+1)
# 10 p = p + 1;
$stop();
end
// Connect up your module here...
endmodule
The 4-bit register 'p' gives you the four individual signals you need to stimulate you module with.
