Am trying to solve a parking slot problem where an individual has 4 parking spaces outside of his/her apartment complex. this individual wants to know when two adjacent spaces are open as he/she does not want anyone to park next to their car. (normally, this person parks at the end of a large parking lot to avoid any scrapes or scratches). this individual proceeds to set up pressure switches in the parking spaces and has a logic indicator in their apartment building. they want one logic indicator to activate if two adjacent spaces become open, another logic indicator to activate if three adjacent spaces become open, a third if all spaces are open and a fourth if one space is open (in case they choose to risk it).
i am having problems with the testbench. it doesn't generate the desired output waves when i run it in modelsim. any help would be appreciated.
testbench module parking_lot_tb; wire p1 = 1'b0; wire p2 = 1'b0; wire p3 = 1'b0; wire p4 = 1'b0; wire a1; wire a2; wire a3; wire a4; reg clk; parking_lot dut( p1, p2, p3, p4, a1, a2, a3, a4 ); initial begin clk = 1; end always begin assign# 100 p1 = ~( p1); assign# 200 p2 = ~( p2); assign# 300 p3 = ~( p3); assign# 400 p4 = ~( p4); end initial $monitor($stime,,clk,,a1,,a2,,a3,,a4,,); endmodule Main code: module parking_lot( p1, p2, p3, p4, a1, a2, a3, a4 ); input p1; input p2; input p3; input p4; output a1; output a2; output a3; output a4; assign a1 = ( ( ( p1 | p2 ) | p3 ) | p4 ); assign a2 = ( ( ( p1 & p2 ) | ( p2 & p3 ) ) | ( p3 & p4 ) ); assign a3 = ( ( ( ( p1 & p2 ) & p3 ) & ~( p4) ) | ( ( p2 & p3 ) & p4 ) ); assign a4 = ( ( ( p1 & p2 ) & p3 ) & p4 ); endmodule
I suggest you generate a 4-bit, registered, counter that generates the 16 different combinations of slot availability possible. Connect each bit of the counter to your p1-p4 module input signals.
There are several ways in which you could generate this stimulus - I'm not sure yours is one of them :oops: You might try this: module tb (); reg [3:0] p; integer i; initial begin p = 0; for (i=0; i<=15; i=i+1) # 10 p = p + 1; $stop(); end // Connect up your module here... endmodule The 4-bit register 'p' gives you the four individual signals you need to stimulate you module with.
