17265 Discussions
Hi, Is there a way to automatically add the date to the compiled files?
FPern
JoanneSinY_L_Intel
Hi Felix Perning Can you elaborate more on your request. Do you mean add the date in the programming file name If yes, you can refer to the link below https://forums.intel.com/s/question/0D50P00003yyRQXSA2/how-to-change-the-default-name-of-sof-file-in-quartus?language=en_US Thanks Joanne
FPern
Hi!
I want the date in the Name of the compiled .rbf
JoanneSinY_L_Intel
​Hi FPern
Attached document is the tcl file for renaming of .rbf file. Please modify the naming of your file in the tcl file based on your requirement
You can run by using the tcl file below  and change the setting in yr qsf file
set_global_assignment -name POST_FLOW_SCRIPT_FILE "quartus_sh:renamefiles.tcl"
Joanne
JoanneSinY_L_Intel
Hi Felix, May I know any update or should I consider that case to be closed? Thanks Joanne
