17255 Discussions
High-impedance state when simulate FIFO IP core using Modelsim altera
I have generated the FIFO IP-core Using Quartus 12.1 ,and simulated it with Modelsim-altera starter edition. The top-test file and the incentives are as follows:
//---------------------top_test---------------------------------------------------------------------
`timescale 1ns/1ns
module top_test(
output [31:0] q ,
output empty,
output full
wire [31:0] data;
wire data_val;
reg rd_req;
reg data_val_0,data_val_1;
always@(posedge clk) data_val_0<=data_val;
always@(posedge clk) data_val_1<=data_val_0;
always@(posedge clk) rd_req <= data_val_1;
clk_reset_gen clk_reset_gen(
.clk (clk),
.reset_n (reset_n)
data_gen data_gen(
.clk (clk ),
.reset_n (reset_n ),
.data (data ),
.data_val (data_val)
fifo_bbbb fifo_bbbb(
.aclr (~reset_n),
.clock (clk),
.data (data),
.rdreq (rd_req),
.wrreq (data_val),
.empty (empty),
.full (full),
.q (q)
endmodule
//---------------------clk_reset_gen------------------------------------------------------------------------
`timescale 1ns/1ns
module clk_reset_gen(
output reg clk,
output reg reset_n
initial begin
clk =1'b0;
reset_n =1'b0;# 1000 reset_n =1'b0;# 10000 reset_n =1'b1;
end
always# 10 clk = ~clk;
endmodule
//----------------------data_gen-----------------------------------------------------------------------
module data_gen(
input clk,
input reset_n,
output [31:0] data,
output data_val
reg [8:0] counter;
always@(posedge clk or negedge reset_n)begin
if(~reset_n) counter<='b0;
else counter<=counter+1'b1;
end
assign data = {counter[7:0],counter[7:0],counter[7:0],counter[7:0]};
assign data_val = counter[8];
endmodule
http://www.alteraforum.com/forum/attachment.php?attachmentid=11341&stc=1
//-----------end----------------------------------------------------------------
I have compiled the files &#65306;test_top.v,clk_reset_gen,data_gen,fifo_bbbb.v,220model&#65292;altera_mf into the same library&#65292;but all the output signals are high-impedance state.When I starting the modelsim_altera through the Nativelink to simulate &#65292;I got the same result . Please help me ,thank you very much ! !
DNguy4
Did you find out the cause of this? I see something similar with my design.
