17245 Discussions
How can I use altera_avalon_sc_fifo in a VHDL simulation?
ONors
I use altera_avalon_sc_fifo (Avalon_ST Single Clock FIFO) in qsys. When I generate HDL I select VHDL for simulation I get <qsys_name>/altera_avalon_sc_fifo_161/sim/altera_avalon_sc_fifo.v and <qsys_name>/<subsystem_name>/sim/<qsys_name><subsystem_name>_<gibberish>_sc_fifo_<instance_name>.vhd.
altera_avalon_sc_fifo.v compiles in Modelsim, but the vhd file does not.
If I comment out these lines it compiles.
for sc_fifo_n0 : altera_avalon_sc_fifo use entity jesd204b_ed_qsys_altera_avalon_sc_fifo_161.altera_avalon_sc_fifo;
Now I can instantiate the fifo in my testbench and compile the testbench. In modelsim I can see the sc_fifo componet under the sim tab as an instance of the design unit altera_avalon_sc_fifo. I can look into the hierarchy of the instance and I see the Verilog parameters as I expect them to be, I see the nets and registers. However the instance does nothing. I see a valid packet coming in but nothing going out, except for valid. The same FIFO works in hardware.altera_avalon_sc_fifo.png
AnandRaj_S_Intel
If possible can you share the project ?
Issue may be due to bench.
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
