17250 Discussions
How many pipeline did I used in Mega Core FFT v12. Quartus II?
Hello, I used Megacore function to create a FFT block with 1024 points length.
The resource is showed below, but I don't know how how many pipeline does it use to calculate a cycle.
So How many pipeline does use?
By the way, I want create a smaller FFT, for example: 2 bits, 32 points. How can I do when the Megacore limits them atleast 8 bit and 64 points length?
LEs
3191
Memory Bits
90112
-- M9K RAM Blocks
11
-- M144K RAM Blocks
-- MLAB RAM Blocks
DSP Block 9-bit elements
Transform Calculation Cycles
1024
Block Throughput Cycles
1024
