17259 Discussions
How to Stop code execution
Hello all..
In my code(Model sim), if i select "Run All" then it goes infinite time.(Ie its not stopping at the end of my clock cycle but goes infinite loop and for seeing output i have to stop(Simulation -> break) it then and then only i can see out put.
How can i stop it at the end of my code..
for exmaple..
architecture behav of FA_calc is
if (clk = '1' and clk'event) then
do something...
end if;
end process;
Sd : process(mydata)
begin
end if;
end process Sd1;
end behav;
it should be stop at the end of end behv but its goes to infinite time.How to stop it at then edn of endbehav.
Thanking you.
Are you using a test bench to simulate this code? After all of your code lines are executed, use $stop in your test bench to terminate the simulation.
No..I am not using test benach but i got my solution..
http://www.velocityreviews.com/forums/t57165-how-to-stop-simulation-in-vhdl.html
Even though you had to find it on your own, thanks for posting the solution. It's nice to see closure on these.
