17255 討論
How to Use LPM_FF(DFF, INV..etc) from Insert Symbol in quartus prime? How to add this mega-function libraries.
BDE
初學者
3,308 檢視
Explain in detail steps.
below are steps are done
LIBRARY lpm;
USE lpm.lpm_components.all;
still error
Error (10346): VHDL error at lpm_inv_0.vhd(43): formal port or parameter "LPM_WIDTH" must have actual or default value
Error (10784): HDL error at lpm_pack.vhd(219): see declaration for object "LPM_WIDTH"
0 積分
5 回應
Vicky1
員工
2,988 檢視
Please modify the symbol properties & compile again,
Right Click on symbol(LPM_DFF)-> properties-> Parameter as shown below,
if this has not resolved then provide bit more information like,
  1. Quartus edition(Lite/Pro/Std) & Version used
  2. Device part number used
  3. Elaborate about, what exactly you are trying?
Vicky
Vicky1
員工
2,988 檢視
Have you resolved the issue?
Should I consider that case to be closed?
Vicky
Vicky1
員工
2,988 檢視
Please refer the attached screenshot & try at your end.
please let me know if you have any different concern.
Vicky
BDE
初學者
2,988 檢視
Symbol synthesis will work,
Can you try to convert the same symbol to VHDL and synthesis.
regards,
Balakrishna
Vicky1
員工
2,988 檢視
Hi Balakrishna,
After successfully synthesis(my last post) , instantiate it in top module like below,
  1. Open .bdf file
  2. File-> Create/Update->Create VHDL component declaration component files for current file(It will create .cmp file)
  3. Open that .cmp file & instantiate it in top module & then compile that top module.
Vicky
回覆
