17244 Discussions
How to cast a large std_logic_vector to an array of smaller ones?
Hi again,
For my project, I've defined a custom data type which actually is an array of 16 8-bit std_logic_vectors:
TYPE census_line IS ARRAY(0 TO 15) OF std_logic_vector(7 downto 0);
However from a memory module, all I get is a single, large 128-bit std_logic_vector.
I tried to cast the large vector tor a census_line, but all I get is:
census_line(vector): Error (10305): VHDL Type Conversion error at stereo.vhd(61): cannot convert type "std_logic_vector" to type "census_line"
Is there any way to cast it still?
Thank you and regards, Reggi
Use a function containing a loop that maps the input std_logic_vector into your census_line type, i.e.,
function to_census_line (slv : in std_logic_vector) returns census_line is variable result : census_line; begin for i in 0 to 15 loop result(i) <= slv(8*i+7 downto i); end loop; return result; end function;
This function needs to go after the census_line type definition.
I just typed this directly into the forum, you'll have to debug any VHDL errors :)
Cheers,
Dave
Hi Dave,
Thanks a lot for your suggestion - with a few modifications it works as expected :)
On the downside however, the resource-requirements for this unit increase considerably, just by changing:
TYPE census_line IS ARRAY(0 TO 15) OF UNSIGNED(7 downto 0); TYPE census_block IS ARRAY(0 TO 15) OF census_line;
to:
TYPE census_line IS ARRAY(0 TO 15) OF std_logic_vector(7 downto 0); TYPE census_block IS ARRAY(0 TO 15) OF std_logic_vector(127 downto 0);
and using the conversion method mentioned, my design increases from ~1.1k ALMs to 2.3k ALMs.
Any ideas what is going wrong here?
Thanks, Reggi
Problem solved :)
Using larger std_logic_vectors somehow reduced optimization freedome for quartus.
When I switched to M10K-blocks for instead of registers, resource-useage went down to 1.1k ALMs which is actually great :)
Thanks!
The function just maps the two different data types, it uses zero resources.
As you have determined, the difference was in what your hardware was doing with those data types :)
Cheers,
Dave
