17255 Discussions
How to constraint design to meet Recovery Timing
I have a Cyclone III FPGA design. Quartus II generates a few of Recovery Timing violations. The path info is posted here:
Info (332115): Report Timing: Found 1 recovery paths (1 violated). Worst case slack is -4.863
Info (332115): -to_clock [get_clocks {inst|the_ddr|ddr_controller_phy_inst|ddr_phy_inst|ddr_phy_alt_mem_phy_inst|clk|pll|altpll_component|auto_generated|pll1|clk[0]}]
Info (332115): -recovery
Info (332115): -stdout
Info (332115): Path# 1: Recovery slack is -4.863 (VIOLATED)
Info (332115): 2210.000 2210.000 latch edge time
Info (332115): 2210.856 0.856 R clock network delay
Info (332115): 2210.706 -0.150 clock uncertainty
Info (332115): 2210.647 -0.059 uTsu CTIDSCCM:inst|ddr_clock_crossing:the_ddr_clock_crossing|ddr_clock_crossing_upstream_fifo:the_upstream_fifo|dcfifo:upstream_fifo|dcfifo_u1g1:auto_generated|altsyncram_di31:fifo_ram|q_b[1]
Info (332115):
Info (332115): Data Arrival Time : 2212.521
Info (332115): Data Required Time : 2210.647
Info (332115): Slack : -1.874 (VIOLATED)
Info (332115): 33.332 33.332 latch edge time
Info (332115): 33.909 0.577 R clock network delay
Info (332115): 34.236 0.327 clock pessimism
Info (332115): 34.216 -0.020 clock uncertainty
Info (332115): 34.234 0.018 uTsu CTIDSCCM:inst|peri_clock_crossing:the_peri_clock_crossing|peri_clock_crossing_downstream_fifo:the_downstream_fifo|dcfifo:downstream_fifo|dcfifo_euf1:auto_generated|rdemp_eq_comp_msb_aeb
Info (332115):
Info (332115): Data Arrival Time : 34.855
Info (332115): Data Required Time : 34.234
Info (332115): Slack : -0.621 (VIOLATED)
Info (332115): 30.066 30.066 latch edge time
Info (332115): 30.466 0.400 R clock network delay
Info (332115): 30.326 -0.140 clock uncertainty
Info (332115): 30.279 -0.047 uTsu CTIDSCCM:inst|ddr_clock_crossing:the_ddr_clock_crossing|ddr_clock_crossing_downstream_fifo:the_downstream_fifo|dcfifo:downstream_fifo|dcfifo_tsf1:auto_generated|altsyncram_ji31:fifo_ram|q_b[30]
Info (332115):
Info (332115): Data Arrival Time : 34.414
Info (332115): Data Required Time : 30.279
Info (332115): Slack : -4.135 (VIOLATED)
Info (332115): 2210.927 0.927 R clock network delay
Info (332115): 2210.777 -0.150 clock uncertainty
Info (332115): 2210.730 -0.047 uTsu CTIDSCCM:inst|ddr_clock_crossing:the_ddr_clock_crossing|ddr_clock_crossing_upstream_fifo:the_upstream_fifo|dcfifo:upstream_fifo|dcfifo_u1g1:auto_generated|altsyncram_di31:fifo_ram|q_b[1]
Info (332115):
Info (332115): Data Arrival Time : 2212.416
Info (332115): Data Required Time : 2210.730
Info (332115): Slack : -1.686 (VIOLATED)
Info (332115): 34.028 0.696 R clock network delay
Info (332115): 34.297 0.269 clock pessimism
Info (332115): 34.277 -0.020 clock uncertainty
Info (332115): 34.297 0.020 uTsu CTIDSCCM:inst|peri_clock_crossing:the_peri_clock_crossing|peri_clock_crossing_downstream_fifo:the_downstream_fifo|dcfifo:downstream_fifo|dcfifo_euf1:auto_generated|rdemp_eq_comp_msb_aeb
Info (332115):
Info (332115): Data Arrival Time : 34.386
Info (332115): Data Required Time : 34.297
Info (332115): Slack : -0.089 (VIOLATED)
Info (332115): 30.123 0.057 R clock network delay
Info (332115): 29.983 -0.140 clock uncertainty
Info (332115): 29.959 -0.024 uTsu CTIDSCCM:inst|ddr_clock_crossing:the_ddr_clock_crossing|ddr_clock_crossing_downstream_fifo:the_downstream_fifo|dcfifo:downstream_fifo|dcfifo_tsf1:auto_generated|altsyncram_ji31:fifo_ram|q_b[30]
Info (332115):
Info (332115): Data Arrival Time : 32.377
Info (332115): Data Required Time : 29.959
Info (332115): Slack : -2.418 (VIOLATED)
Info (332115): 2210.284 0.284 R clock network delay
Info (332115): 2210.134 -0.150 clock uncertainty
Info (332115): 2210.142 0.008 uTsu CTIDSCCM:inst|ddr_clock_crossing:the_ddr_clock_crossing|ddr_clock_crossing_upstream_fifo:the_upstream_fifo|dcfifo:upstream_fifo|dcfifo_u1g1:auto_generated|a_graycounter_i47:rdptr_g1p|counter5a2
Info (332115):
Info (332115): Data Arrival Time : 2211.008
Info (332115): Data Required Time : 2210.142
Info (332115): Slack : -0.866 (VIOLATED)
Info (332115): 2240.000 2240.000 latch edge time
Info (332115): 2240.682 0.682 R clock network delay
Info (332115): 2240.822 0.140 clock uncertainty
Info (332115): 2240.923 0.101 uTh CTIDSCCM:inst|ddr_clock_crossing:the_ddr_clock_crossing|ddr_clock_crossing_upstream_fifo:the_upstream_fifo|dcfifo:upstream_fifo|dcfifo_u1g1:auto_generated|altsyncram_di31:fifo_ram|ram_block11a1~portb_address_reg0
Info (332115):
Info (332115): Data Arrival Time : 2240.820
Info (332115): Data Required Time : 2240.923
Info (332115): Slack : -0.103 (VIOLATED)
It seems to me that all the paths violated are related to DDR mem. The design is based on standard Cyclone III neek. I have tried serveral variations, and with different Timing Analysis settings (as suggested by TQ advsier, and fourm's other leads, etc.) but all with similar violation warning. They might be on the false paths. But it is involved with DDR memory, I have no clues that those paths can be set to false paths. Whatelse can I do to constain my design to meet the timing requirements?
Thank you in advance,
David
Did You add SDC file generated by DDR memory core? And did You run TCL generated by the same core?
Analyze in TimeQuest, as it gives more information. Is the source register in the DDR controller, or is it something generated outside of the DDR megafunction and driving in? Is it crossing clock domains? (I think it may be, but not sure). I'm guessing this is a false path, but not quite enough info.
Thank you for yuor promptly reply. The SDC file generated by DDR memory core is in. I did not run TCL manually. I'm busy working on prototype board testing etc. I have to postpone this issue.
david
