17257 Discussions
simplest way to make a pin high or low in verilog
someone kindly suggest a simplest way to make a pin high or low in verilog
the board i am using is DE2 115
thank you
module fpga_main { out0, out1, // more i/o pins }; output out0; output out1; assign out0 = 1'b0; //pin low assign out1 = 1'b1; //pin high // other code endmodule
Then use Quartus pin assignment feature to route out0 and out1 signals to proper fpga pins
