17268 Discussions
How to convert sof file to pof file by using tcl command?
NuvKFC
Unfortunately, I need to frequently convert sof file to pof file.
It's time consuming if I manually do it.
How to convert follows picture to TCL command?
Could someone please tell me some information?
I can't find any command to do it.
Thank you very much.
Advanced:
Properties:
NurAiman_M_Intel
Thank you for contacting Intel community.
You can use the quartus_cpf command to convert the programming file. You can refer to page 2-16 of the documentation https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/manual/tclscriptrefmnl.pdf for more detailed usage information and example. Please ensure to use latest quartus version or version 17.1 and above.
Aiman
NurAiman_M_Intel
Aiman
NuvKFC
Hi NurAiman_M_Intel
    Thank you, NurAiman_M_Intel, very much.
I will study it latter.
I have a question first.
The question is that I find my Linux system only supporting quartus_sh now.
Can I use the quartus_sh command to execute "quartus_cpf " command?
NurAiman_M_Intel
The answer is no. This is due to the function are different between this command.
Aiman
NuvKFC
Hi NurAiman_M_Intel
I get it. Thank you very much.
And how to config the mode? I use the Active Serial mode.
But I can't find it in the follow picture.
NurAiman_M_Intel
What do you mean by config the mode? Do you mean Active serial code?
Active serial is AS.
Aiman
NuvKFC
Hi NurAiman_M_Intel
Yes. As the follows picture, I use Active serial mode.
From the quartus --qhelp, Active serial mode is ASx1 as the follows picture, right?
NurAiman_M_Intel
Yes, that's correct.
Aiman
NuvKFC
Hi NurAiman_M_Intel
    OK, I get it. Thank you, NurAiman_M_Intel, very, very, much.
NurAiman_M_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
NuvKFC
Hi NurAiman_M_Intel
    OK, Thank you very, very, much.
