17263 Discussions
How to deal with the Out-of-Order Loop Iterations in single work-item kernel?
Today I tried to use single work-item kernel. I have a nested loop. In Loop Report, I found my outer loop not pipelined due to:
loop iteration ordering: iterations may get out of order with respect to the inner loop,
as the number of iterations of the inner loop may be different for different iterations of this loop.
I understood this problem. for different outer iterations of outer loop, actually i need different number of iterations of inner loop. And in "out-of-order loop iterations" section of the best practices guide, I found an example, it is just similar to my code:
__kernel void order( __global unsigned* restrict input, __global unsigned* restrict output, int N ) { unsigned sum=0; for (unsigned i = 0; i < N; i++) { for (unsigned j = 0; j < i; j++) sum += input; } output = sum; }
But no solution is mentioned here. How can I pipeline the loop? Or how to deal with this problem? If I use multiple kernels, will it work?
Sorry I just think about multiple kernels... Maybe it will solve this problem, is it right?
Thanks in advance.
You can pipeline the loop like this:
__kernel void order( __global unsigned* restrict input, __global unsigned* restrict output, int N ) { unsigned sum=0; for (unsigned i = 0; i < N; i++) { for (unsigned j = 0; j < N; j++) if (j < i) sum += input; } output = sum; }
However, since in this case both of the loops will run N times, depending on N, this code could actually be slower than the original case due to redundant computation. For such unpipelineable loops, it is actually preferred to use NDRange kernels.
--- Quote Start ---
--- Quote End ---
Thanks very much.
My code is more complex then it is hard to make the same number of inner iterations... Yes, it is actually preferred to use NDRange kernels...
