17259 Discussions
how to delete a part of the design using ECOs
Hi all, I have a circuit design containing 2 parts, the first part can run on it own, while the second part gets some input from the first part and gives some outputs.
Is there any way that after compiling, I can use ECOs mode to delete the second part so that I can have two netlists, one with the second part and one without the second part?
Because I want to use side-channel to evaluate what the difference caused by the second part only.
I tried incremental design technique but it didn't give the result I expected. The routing and placement of the first part in 2 designs (one with the second part, one without the second part) are still somewhat slightly different.
I want to keep it exactly the same.
Thank you so much for reading.
For ECO changes using Altera Quartus Chip planner & Resource property Editor refer the following link,
https://www.youtube.com/watch?v=rnhn5n7os78
Best Regards
Vikas Jathar
Intel Customer Support – Engineering
(Under Contract to Intel)
