Today I tried to use single work-item kernel. I have a nested loop. In Loop Report, I found my outer loop not pipelined due to: loop iteration ordering: iterations may get out of order with respect to the inner loop,as the number of iterations of the inner loop may be different for different iterations of this loop. I understood this problem. for different outer iterations of outer loop, actually i need different number of iterations of inner loop. And in "out-of-order loop iterations" section of the best practices guide, I found an example, it is just similar to my code:
__kernel void order( __global unsigned* restrict input,
__global unsigned* restrict output, int N ) {
unsigned sum=0;
for (unsigned i = 0; i < N; i++) {
for (unsigned j = 0; j < i; j++)
sum += input;
output = sum;
But no solution is mentioned here. How can I pipeline the loop? Or how to deal with this problem? If I use multiple kernels, will it work?
Sorry I just think about multiple kernels... Maybe it will solve this problem, is it right?
Thanks in advance.- Mark as New
You can pipeline the loop like this:
unsigned sum=0;
for (unsigned j = 0; j < N; j++)
if (j < i) sum += input;
output = sum;
However, since in this case both of the loops will run N times, depending on N, this code could actually be slower than the original case due to redundant computation. For such unpipelineable loops, it is actually preferred to use NDRange kernels.
--- Quote Start --- You can pipeline the loop like this:
unsigned sum=0;
output = sum;
However, since in this case both of the loops will run N times, depending on N, this code could actually be slower than the original case due to redundant computation. For such unpipelineable loops, it is actually preferred to use NDRange kernels. --- Quote End --- Thanks very much. My code is more complex then it is hard to make the same number of inner iterations... Yes, it is actually preferred to use NDRange kernels...
