Comunicados
17268 Discussões
How to disable SignalTap instance?
NuvKFC
Novo colaborador I
3.154 Visualizações
I have a "SignalTap.stp" file which contains many signaltap instances as follows picture which contain two signaltap instances.
I only want to disable the first signaltap instance.
Could someone please tell me how do that? Thank you very much.
1 Solução
sstrell
Colaborador honorário III
3.106 Visualizações
No there should be checkboxes in the Instance Manager at the top.  Maybe that's a Pro edition only feature because I have it.  Try right-clicking an instance to see if there is an option to disable an instance that way.
Ver solução na publicação original
8 Respostas
sstrell
3.130 Visualizações
Disable as in remove the Signal Tap hardware for just instance 1 when you recompile the design?  There's an "Enabled" checkbox in the Instance Manager in the .stp file to disable individual instances.
NuvKFC
Novo colaborador I
3.113 Visualizações
Hi sstrell
    Thank you, sstrell, very much. Does the "Enabled" checkbox, you mean is as follows picture?
I think that it only can disable signals that users don't want to see in the Signaltap. Am I right?
Or it also can disable whole instance?
sstrell
3.107 Visualizações
NuvKFC
Novo colaborador I
3.041 Visualizações
Hi sstrell
    Thank you, sstrell, very much. I can't find it. Maybe my tool's version is too old. Thank you very much.
RichardTanSY_Altera
3.093 Visualizações
May I know which Quartus version are you using? Quartus Standard also has the Enabled check box in the Instance Manager.
NuvKFC
Novo colaborador I
3.057 Visualizações
Hi RichardTanSY_Intel
    Thank you, RichardTanSY_Intel, very much. I'm using the "Quartus13.1 full version". Does it's too old? Thank you very much.
sstrell
3.049 Visualizações
That's 8 years old.  The option may not have been available back then.
NuvKFC
Novo colaborador I
3.045 Visualizações
Hi sstrell
       Thank you, sstrell, very much. OK 0.0. I get it. If I can, I will try the newer version tool. Thank you very much.
Responder
