- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
When I compile my project, I got a warning as below, --- Quote Start --- Warning: Timing-driven compilation is disabled - timing performance will not be optimized --- Quote End --- I checked the setting file. I assume settings about timing are set to ON. I wonder do I make some mistake with .qsf file? Regards, Clairlyn Some sections of my .qsf:# Classic Timing Assignments
set_global_assignment -name TIMEQUEST_MULTICORNER_ANALYSIS ON
set_global_assignment -name TIMEQUEST_DO_CCPP_REMOVAL ON
# Analysis & Synthesis Assignments
set_global_assignment -name STATE_MACHINE_PROCESSING "ONE-HOT"
set_global_assignment -name CYCLONE_OPTIMIZATION_TECHNIQUE SPEED
set_global_assignment -name REMOVE_DUPLICATE_LOGIC OFF
set_global_assignment -name ADV_NETLIST_OPT_SYNTH_GATE_RETIME ON
set_global_assignment -name SYNTH_TIMING_DRIVEN_SYNTHESIS ON
set_global_assignment -name SAFE_STATE_MACHINE ON
set_global_assignment -name PRE_MAPPING_RESYNTHESIS ON
# Fitter Assignments
set_global_assignment -name OPTIMIZE_MULTI_CORNER_TIMING ON
set_global_assignment -name OPTIMIZE_TIMING "NORMAL COMPILATION"
set_global_assignment -name FINAL_PLACEMENT_OPTIMIZATION ALWAYS
set_global_assignment -name SEED 3
set_global_assignment -name PHYSICAL_SYNTHESIS_COMBO_LOGIC ON
set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_DUPLICATION ON
set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_RETIMING ON
set_global_assignment -name FITTER_EFFORT "STANDARD FIT"
set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR 1
set_global_assignment -name STRATIX_DEVICE_IO_STANDARD LVTTL
set_global_assignment -name ROUTING_BACK_ANNOTATION_MODE NORMAL
set_global_assignment -name PHYSICAL_SYNTHESIS_ASYNCHRONOUS_SIGNAL_PIPELINING ON
set_global_assignment -name ECO_OPTIMIZE_TIMING ON
set_global_assignment -name FORCE_CONFIGURATION_VCCIO ON
- Balises:
- Intel® Quartus® Prime Software
Lien copié
5 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
You need to compile your sdc in Time Quest Analyzer. Then the synthesis will be sdc driven.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
--- Quote Start --- You need to compile your sdc in Time Quest Analyzer. Then the synthesis will be sdc driven. --- Quote End --- I saved constraints to .sdc File in TimeQuest Analyzer, and added the .sdc to my project. After doing this, run a full compilation. Are my steps correct? thx
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
You need to add this to your .qsf file for timing-driven fitting:
set_global_assignment -name ROUTER_TIMING_OPTIMIZATION_LEVEL NORMAL Also, if you want synthesis to be timing-driven, add this also: set_global_assignment -name SYNTH_TIMING_DRIVEN_SYNTHESIS ON There are check boxes for both of these settings in the Settings dialog box.- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
After adding ROUTER_TIMING_OPTIMIZATION_LEVEL NORMAL to my .qsf file, it's done.
I really appreciate your help. I wonder if quartus wouldn't optimize router timing without this line in .qsf file?- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I'm not sure, but the choices for this setting are MINIMUM, MAXIMUM, and NORMAL, with NORMAL the default. Usually if a setting is not in the .qsf file, the default is assumed by Quartus II.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
