17245 Discussions
Trying to integrate verilog file into vhdl project
Hi
I'm sure this question has been asked before but I can't seem to find an answer to it.
I am trying to use a verilog file in a vhdl project like this:
u1 : entity work.sdram port map(
CLOCK_50=>systemClk,
SW=>input,
LEDG=>sdramLedG,
LEDR=>sdramLedR
However when I try to compile it gives
Error (10481): VHDL Use Clause error at sdram_driver_test.vhd(25): design library "work" does not contain primary unit "sdram"
Trying without the work doesn't work either.
Any ideas?
add a VHDL component declaration for sdram. i don't think direct instantiation will work mixed language without a component declaration
You have to treat the verilog like a black box. so you will need a component declaration else the VHDL has no knowledge of the existance of the Verilog, and hence throws the error. This way you can instantial verilog or AHDL entities from VHDL.
