17268 Discussions
How to enable Timing-driven compilation
When I compile my project, I got a warning as below,
--- Quote Start ---
Warning: Timing-driven compilation is disabled - timing performance will not be optimized
--- Quote End ---
I checked the setting file. I assume settings about timing are set to ON.
I wonder do I make some mistake with .qsf file?
Clairlyn
Some sections of my .qsf:
# Classic Timing Assignments # ========================== set_global_assignment -name TIMEQUEST_MULTICORNER_ANALYSIS ON set_global_assignment -name TIMEQUEST_DO_CCPP_REMOVAL ON # Analysis & Synthesis Assignments # ================================ set_global_assignment -name STATE_MACHINE_PROCESSING "ONE-HOT" set_global_assignment -name CYCLONE_OPTIMIZATION_TECHNIQUE SPEED set_global_assignment -name REMOVE_DUPLICATE_LOGIC OFF set_global_assignment -name ADV_NETLIST_OPT_SYNTH_GATE_RETIME ON set_global_assignment -name SYNTH_TIMING_DRIVEN_SYNTHESIS ON set_global_assignment -name SAFE_STATE_MACHINE ON set_global_assignment -name PRE_MAPPING_RESYNTHESIS ON # Fitter Assignments # ================== set_global_assignment -name OPTIMIZE_MULTI_CORNER_TIMING ON set_global_assignment -name OPTIMIZE_TIMING "NORMAL COMPILATION" set_global_assignment -name FINAL_PLACEMENT_OPTIMIZATION ALWAYS set_global_assignment -name SEED 3 set_global_assignment -name PHYSICAL_SYNTHESIS_COMBO_LOGIC ON set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_DUPLICATION ON set_global_assignment -name PHYSICAL_SYNTHESIS_REGISTER_RETIMING ON set_global_assignment -name FITTER_EFFORT "STANDARD FIT" set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR 1 set_global_assignment -name STRATIX_DEVICE_IO_STANDARD LVTTL set_global_assignment -name ROUTING_BACK_ANNOTATION_MODE NORMAL set_global_assignment -name PHYSICAL_SYNTHESIS_ASYNCHRONOUS_SIGNAL_PIPELINING ON set_global_assignment -name ECO_OPTIMIZE_TIMING ON set_global_assignment -name FORCE_CONFIGURATION_VCCIO ON
You need to compile your sdc in Time Quest Analyzer. Then the synthesis will be sdc driven.
--- Quote Start ---
--- Quote End ---
I saved constraints to .sdc File in TimeQuest Analyzer, and added the .sdc to my project. After doing this, run a full compilation.
Are my steps correct? thx
You need to add this to your .qsf file for timing-driven fitting:
set_global_assignment -name ROUTER_TIMING_OPTIMIZATION_LEVEL NORMAL
Also, if you want synthesis to be timing-driven, add this also:
There are check boxes for both of these settings in the Settings dialog box.
After adding ROUTER_TIMING_OPTIMIZATION_LEVEL NORMAL to my .qsf file, it's done.
I really appreciate your help.
I wonder if quartus wouldn't optimize router timing without this line in .qsf file?
I'm not sure, but the choices for this setting are MINIMUM, MAXIMUM, and NORMAL, with NORMAL the default. Usually if a setting is not in the .qsf file, the default is assumed by Quartus II.
