17268 Discussions
How to get USB Blaster II in Programmer? (Using Ubuntu and Quartus Prime Lite 19.1)
NSook
I'm currently trying to set up the USB Blaster II for a Max 10 10M08 Evaluation Kit using Ubuntu ran on Virtualbox. On terminal, it says that the USB blaster is connected (using lsusb). I've also created the file named usbblaster.rules. Not sure as to why it's not showing up as hardware in the programmer menu when I try to add it. Any ideas or any thing I could do to make this work? Thank you.
ShafiqY_Intel
I believe you submitted the same as issue thread here (https://forums.intel.com/s/question/0D50P00004cFPJE/how-to-get-usb-blaster-ii-under-programmer-in-quartus-prime-lite)
send me the screenshot first, and we will further debug on this.
Cheers
