17264 Discussions
How to implement two-dimensional array using HDL?
I need to creat many tables in FPGA, and these tables are used to store two-dimensional array data.
For example, when I get (x,y) value and then find the coordinate according this (x,y) value.
These table also can be updated, so they must be strore in "RAM" (not in "ROM").
But I found some comments about the two-dimensional array, which said that two-dimensional array is just used on simulation, for two-dimensional array couldn't be synthesized to circuit. If so, how to implement my application in my FPGA? Does ALTERA have some functions (or mega core) like this?
A 2-D array (N,M) can be simply mapped to a 1-D array (N*M). If N and M are both powers of two, just concatenate the address vectors. In so far, no special functions are needed.
--- Quote Start ---
--- Quote End ---
Dear FvM:
Good idea!
But i have another question. For my application, the N=M=9, the QII can only implement memory which depth is below 65536. It seems that i shouldn't merge samll memorys to a big one, for i must find my result according N&M's value.:cry:
why cant you round N and M up to 16? then you can use sensible addressing and concatenate N and M?
