17255 Discussions
Need to feed two buses with one output
Hello everybody,
In my top level design in Quartus I am trying to feed the LSB of two buses
with a signal which comes out of a block, usually I do this by naming the output signal the same name as the LSB of the bus:
lv_to_uc_status_i[0]
But I cannot name the output signal twice, so how can I tell Quartus that I need to feed two buses with this signal ?
Eric
--- Quote Start ---
Hello everybody,
Eric
--- Quote End ---
Hi Eric,
what are you using Verilog, VHDL schematics
Kind regards
GPK
Hello Pletz,
Thanks for your answer !
I am using Schematics, in Verilog this is pretty easy actually, turns out
this is also pretty easy in schematics. I need to feed the signal into
2 wire buffers, on the other side of these buffers I can feed two inputs
in the top level. See the Snagit picture I have attached below.
Again, thanks for your answer !!
Cheers,
Eric
