- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello everybody,
In my top level design in Quartus I am trying to feed the LSB of two buses with a signal which comes out of a block, usually I do this by naming the output signal the same name as the LSB of the bus: lv_to_uc_status_i[0] But I cannot name the output signal twice, so how can I tell Quartus that I need to feed two buses with this signal ? Thanks, Eric링크가 복사됨
2 응답
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
--- Quote Start --- Hello everybody, In my top level design in Quartus I am trying to feed the LSB of two buses with a signal which comes out of a block, usually I do this by naming the output signal the same name as the LSB of the bus: lv_to_uc_status_i[0] But I cannot name the output signal twice, so how can I tell Quartus that I need to feed two buses with this signal ? Thanks, Eric --- Quote End --- Hi Eric, what are you using Verilog, VHDL schematics Kind regards GPK
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Pletz,
Thanks for your answer ! I am using Schematics, in Verilog this is pretty easy actually, turns out this is also pretty easy in schematics. I need to feed the signal into 2 wire buffers, on the other side of these buffers I can feed two inputs in the top level. See the Snagit picture I have attached below. Again, thanks for your answer !! Cheers, Eric
