17268 Discussions
How to include user vhdl defined package in ModelSim-Altera RTL Simulation?
AIbra11
I can compile my design in Quartus Prime Lite Edition.
I can run the RTL Simulation using ModelSi -Altera well.
The problem happens when I included a package vhdl file as follows:
1- I created user_pkg.vhd file and placed it in Sources folder, the file has a package called: example_package
2- The Testbench file imports example package as follows:
library work;
use work.example_package.all;
3- Quartus compiles successfully
4- Then ModelSim RTL Simulation crashes at:
# ** Error: (vcom-11) Could not find work.example_package
# ** Error (suppressible): Cannot find expanded name "work.example_package".
Unknown expanded name.
I solved it by manually adding:
vcom -93 -work work {C:/intelFPGA_lite/Projects/....../user_pkg.vhd}
to the run_msim_rtl_verilog.do file
how to do that automatically in Quartus so that I don't have to do it everytime I launch rtl_sim?
RichardTanSY_Altera
Try adding the user_pkg.vhd file in your projects and see if it helps.
AIbra11
Thank you Richard, however it didn't help,
I actually solved it by adding :
vcom -93 -work work {C:/intelFPGA_lite/Projects/......./Sources/user_pkg.vhd}
to:
C:/intelFPGA_lite/Projects/......./simulation/modelsim/[project_name]_run_msim_rtl_verilog.do
to include it in the list of compiled files
The problem is I have to do this manually, I hope there was a way to configure it automatically from Quartus.
RichardTanSY_Altera
