17255 Discussions
How to install Quartus II on Ubuntu 11.10
So from a fresh install of Ubuntu:
11.1sp1_216_quartus_free_linux.sh
chmod +x 11.1sp1_216_quartus_free_linux.sh
./11.1sp1_216_quartus_free_linux.sh
Creating directory 11.1sp1_216_quartus_free_linux
Verifying archive integrity... All good.
Uncompressing Quartus II Web Edition (Free).......................................................................................................................................................................................................................................................................................................................................................................................................Extraction failed.
So I try to change couple of things that didn't help?
sudo dpkg-reconfigure dash <no> to set bash as default.
ls -al /bin/sh
lrwxrwxrwx 1 root root 4 2012-01-25 08:41 /bin/sh -> bash
sudo apt-get install ia32-libs csh
any ideas?
# UPDATE: [SOLVED]
sudo bash ./11.1sp1_216_quartus_free_linux.sh
Add the following lines to the /etc/udev/rules.d/51-usbblaster.rules file.
# USB-Blaster
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666"
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6002", MODE="0666"
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6003", MODE="0666"
sudo apt-get install libxerces-c28
sudo apt-get install lib32icu44
cd altera/11.1sp1/quartus/
sudo cp /usr/lib/libxerces-c.so.28.0 linux64/libaxerces-c.so.26
sudo cp /usr/lib/libicudata.so.44 linux64/libicudata.so.34
sudo cp /usr/lib/libicuuc.so.44.2 linux64/libicuuc.so.33
sudo cp /usr/lib/libicuuc.so.44 ../linux64/libicuuc.so.34
sudo locale-gen en_US
sudo apt-get install gtk2-engines-pixbuf
Hi Pete,
Thank for your help.
I tried your rules, but it does not work. I will keep searching and trying.
Di
Hi all,
I solved this problem.
Actually, when you install Quartus II, you should use sudo bash setup.sh to install it.
Now I can find my DE5 board.
Thank for helps.
Di
Great!.. Glad you got it working.
I remember having to change the soft link in /bin for sh from dash to bash.
Pete
