17252 Discussions
How to install Quartus II on Ubuntu 11.10
So from a fresh install of Ubuntu:
11.1sp1_216_quartus_free_linux.sh
chmod +x 11.1sp1_216_quartus_free_linux.sh
./11.1sp1_216_quartus_free_linux.sh
Creating directory 11.1sp1_216_quartus_free_linux
Verifying archive integrity... All good.
Uncompressing Quartus II Web Edition (Free).......................................................................................................................................................................................................................................................................................................................................................................................................Extraction failed.
So I try to change couple of things that didn't help?
sudo dpkg-reconfigure dash <no> to set bash as default.
ls -al /bin/sh
lrwxrwxrwx 1 root root 4 2012-01-25 08:41 /bin/sh -> bash
sudo apt-get install ia32-libs csh
any ideas?
# UPDATE: [SOLVED]
sudo bash ./11.1sp1_216_quartus_free_linux.sh
Add the following lines to the /etc/udev/rules.d/51-usbblaster.rules file.
# USB-Blaster
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666"
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6002", MODE="0666"
BUS=="usb", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6003", MODE="0666"
sudo apt-get install libxerces-c28
sudo apt-get install lib32icu44
cd altera/11.1sp1/quartus/
sudo cp /usr/lib/libxerces-c.so.28.0 linux64/libaxerces-c.so.26
sudo cp /usr/lib/libicudata.so.44 linux64/libicudata.so.34
sudo cp /usr/lib/libicuuc.so.44.2 linux64/libicuuc.so.33
sudo cp /usr/lib/libicuuc.so.44 ../linux64/libicuuc.so.34
sudo locale-gen en_US
sudo apt-get install gtk2-engines-pixbuf
You probably have a corrupted archive.
Make sure the MD5sum matches what's on the website for the downloaded file.
md5sum should be installed already, if not it will tell you what package you need when you try to use it.
Pete
Try
Don't ask me why ... it worked when I tried it :)
Cheers,
Dave
@anakha (http://www.alteraforum.com/forum/member.php?u=2471
My md5sum was ok ;)
start the installation
If the script is using specific feature of bash that are not supported in sh.
so I replace in the file# !/bin/sh
for # !/bin/bash
and it solve the problem! So Altera should replace sh for bash in there script! Where is there bug report website to tell them?
SUMMARIZED:
KA
hello all!!!
someone can make usbblaster run on ubuntu 11.10????
i did
1 add on /etc/rc.local
mount --bind /dev/bus /proc/bus ln -s /sys/kernel/debug/usb/devices /proc/bus/usb/devices
2 add on /etc/udev/rules.d/51-usbblaster.rules
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c"
and when i did lsusb i see
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 005 Device 002: ID 413c:3012 Dell Computer Corp. Optical Wheel Mouse Bus 005 Device 003: ID 413c:2106 Dell Computer Corp. Dell QuietKey Keyboard Bus 007 Device 004: ID 09fb:6001 Altera -> here
but when i do jtagconfig
No JTAG hardware available
any ideia???
someone can help me ???
thanks
Franz Wagner
ok i solve the problem
it is just permissions problem.......to solve do it
sudo chmod 765 /sys/kernel/debug
and it works!!!
Franz&#65292;in your post, you said you did:
I want to know, if the version is quartus 8.0, should I change anything of the above content?
hi!! good morning
I think for quartus 8 the file is the same, should change only the PATH
cheers
Franz Wagner
Hi, Franz
Thank's for your reply.
I just succeeded install quartus II on Ubuntu11.10. But there are still some problems.
When I compile the hello_word project, I had the message:
**** Build of configuration Debug for project hello_world_0 ****
make -s all includes
Error: no processor component available.
SOPC_BUILDER_PATH may be incorrectly set in your environment.
make[1]: *** [proc_check] Error 1
make: *** [system_project] Error 2
Build completed in 11.841 seconds
hi, good afternoon
yes ......actually i think did it works............which op system d u use?
cheers
Franz Wagner
My problem solved.
Code:
cd /opt/altera9.1/quartus/linux/
sudo mv libX11.so.6 libX11.so.6_old
sudo mv libuuid.so.1 libuuid.so.1_old
--- Quote Start ---
hi, good afternoon
cheers
Franz Wagner
--- Quote End ---
It did works. My system is Ubuntu 11.10.
ok ....
Hi, Franz Thank's for your reply. I just succeeded install quartus II on Ubuntu11.10. But there are still some problems. When I compile the hello_word project, I had the message: **** Build of configuration Debug for project hello_world_0 **** make -s all includes Error: no processor component available. SOPC_BUILDER_PATH may be incorrectly set in your environment. make: *** Error 1 make: *** Error 2 Build completed in 11.841 seconds
this happens because you dont have a nios2 processor in your design......
you need to add a processor, ram memory, jtag uart in sopc builder
or
open a nios2 example for your board
cheers
Franz Wagner
--- Quote Start ---
hello all!!!
i did
--- Quote End ---
This is explain alot on google and also on
http://www.altera.com/download/drivers/dri-usb_b-lnx.html
They should add a INSTALL or README file that explain that it will help ;)
--- Quote Start ---
any ideia???
thanks
Franz Wagner
--- Quote End ---
Still having this issue:
When I open the programmer I have this error on my console :
/home/kapare/altera/11.1sp1/quartus/linux64/jtagd: error while loading shared libraries: libaxerces-c.so.26: wrong ELF class: ELFCLASS32
So this post solve my problem
http://www.alteraforum.com/forum/showthread.php?t=33163
sudo cp /usr/lib/libicudata.so.44 ../linux64/libicudata.so.34
Then finally I was able to select USB-Blaster [1-1]
But since I'm on a virtual machine on Mac the result of flashing is stil FAILED :(
I heard that it was possible from a VM with windows??? will try it...
--- Quote Start ---
--- Quote End ---
I have VirtualBox running under Linux (Centos 6.2) and Windows XP hosts, and they allow the VM to capture the USB-Blaster interface (I've used Ubuntu, Centos, and Windows XP clients in the VM).
Windows 7 will not.
Cheers,
Dave
--- Quote Start ---
Windows 7 will not.
Cheers,
Dave
--- Quote End ---
Thx Dave,
I have Mac OS 10.7 with VMWare Version 4.1.1 (536016) running Windows 7 64bits with Quartus sp2.
I'm able to flash from my Windows 7 Machine :))
NOTE: I only check Program/Configure in the programmer otherwise if I check Verify it fail.
So wait let me try on Ubuntu without the Verify option!!!
RESULT: IT'S WORKING :p
So my problem was the verify option removing this solve my problem.
NOTE: I did test all the options only the Verify + Program/Configure.
Kevyn-Alexandre
Hi Franz,
I got exact problem you met. However, even I try your solution, but I still can not make usb-blaster working on Ubuntu 12.04 64bit.
Do you have any idea what is going on?
--- Quote Start ---
hello all!!!
i did
any ideia???
thanks
Franz Wagner
--- Quote End ---
Attached is my UDEV rules for Ubuntu 12.04. I know I had to modify them due to a change in UDEV system from 10.04 to 12.04, I've also added more variations, due to different dev kit versions of the USB blaster.
Let me know if these work for you. The number in the name: 53 vs 51 is just an ordering item, you can rename it as you wish. Remove the .txt extension. and copy into /etc/udev/rules.d
Let me know if this helps.
Pete
Here what I do since 12.04. Usb-blaster is not always working properly in a VM!
1- sudo apt-get install ia32-libs-multiarch
2- tar xzvf 12.0sp1_232_modelsim_ase_linux.tar.gz
3- sudo bash ./setup
I don't recall if I needed to start quartus as root (sudo) to have access USB-Blaster but I don't think so. We only use quartus for compilation on our build server and program it with Windows or our own devices.
Hope it can help,
-KA
Also did you try to run this comment to list the hardware?
./quartus_jli -n
