I'm trying to make a specified time delay (in seconds) between states. As in: start at state0, wait 3 seconds, move to state1 wait 10, seconds, move to state 2. However there is an input, such that if the input =1 then the time must be reset. So far i though of this:
Basically i made a counter to increment every second (from 24Mhz clock), and then used a binary signal to represent if the time is even or odd. I did this so that in each state i can test if a second has transpired and then increment the internal state clock. Once the internal clock reaches a value, I reset it and then transition to the next state. a to h represent LEDs, L and R are push down buttons on my DE1, FPGA. Ultimately I am just trying to learn how to make a state remain in itself until a certain amount of time has transpired. When I use this code, it doesnt function as i want it to, but im not sure why. library ieee; use ieee.std_logic_1164.all; entity prop is port ( L, R, CLK : in std_logic; a, b, c, d, e, f, g, h : out std_logic ); end prop; architecture behaviour of prop is type state is (stopr, runl, stopl); signal current_s, next_s : state; signal counter : integer range 0 to 24000001 := 0; signal sys_clock : integer range 0 to 36288000 := 0; signal sub_clock : integer range 0 to 36288000 := 0; signal clkevent : std_logic := '0'; signal check : std_logic := '0'; begin state_register: process (CLK) begin if (rising_edge(CLK)) then counter <= counter + 1; if (counter = 24000000) then counter <= 0; sys_clock <= sys_clock + 1; end if; if (sys_clock mod 2 = 0) then clkevent <= '0'; else clkevent <= '1'; end if; current_s <= next_s; end if; end process state_register; next_state_logic: process (current_s, L, R) begin case current_s is when stopr => if (L = '1' OR R = '1') then next_s <= stopr; sub_clock <= 0; elsif (check = NOT(clkevent))then sub_clock <= sub_clock + 1; check <= clkevent; if (sub_clock = 3) then next_s <= runl; sub_clock <= 0; else next_s <= stopr; end if; else next_s <= stopr; end if; when runl => if (L = '1' OR R = '1') then next_s <= stopr; sub_clock <= 0; elsif (check = NOT(clkevent))then sub_clock <= sub_clock + 1; check <= clkevent; if (sub_clock = 11) then sub_clock <= 0; next_s <= stopl; else next_s <= runl; end if; else next_s <= runl; end if; when stopl => if (R = '1') then next_s <= stopr; else next_s <= stopl; end if; when others => next_s <= stopr; end case; end process next_state_logic; output_logic: process (current_s) begin case current_s is when stopr => a <= '1'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; when stopl => a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '1'; when runl => if (sub_clock = 3) then a <= '0'; b <= '1'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; end if; if (sub_clock = 4) then a <= '0'; b <= '0'; c <= '1'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0';end if; if (sub_clock = 5) then a <= '0'; b <= '0'; c <= '0'; d <= '1'; e <= '0'; f <= '0'; g <= '0'; h <= '0';end if; if (sub_clock = 6) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '1'; f <= '0'; g <= '0'; h <= '0';end if; if (sub_clock = 7) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '1'; g <= '0'; h <= '0';end if; if (sub_clock = 8) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '1'; h <= '0';end if; if (sub_clock = 9) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '1'; end if; when others => a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; end case; end process output_logic; end behaviour;Link Copied
I suggest using a clock for all of your code. Im guessing you're getting warnings about latches?
There are several problems with the code. Your sub_clock counter wont work as you think it will because its not in a synchronous process. With your process, it will try and add 1 in a logic loop. You are missing signals in the sensitivity list for the next state logic. Without the correct list, simulation will not behave like the real hardware (you're missing sub_clock, check, clkevent- Mark as New
Okay, so I tried to Fix it by taking a slightly different approach, but it still doeesnt behave the way it should. I'm still very new to VHDL so theres probably some fundamental concept that I'm not understanding.
----------------- CLOCK_start ------------------- library ieee; use ieee.std_logic_1164.all; entity Sys_clk is port ( CLK : in std_logic; Freq : out std_logic ); end Sys_clk; architecture Clock_behave of Sys_clk is signal counter : integer range 0 to 24000001 := 0; signal osc : std_logic := '0'; begin S_reg: process(CLK) begin if (rising_edge(CLK))then counter <= counter + 1; if (counter = 3000000)then if (osc = '0') then osc <= '1'; else osc <= '0'; end if; counter <= 0; end if; Freq <= osc; end if; end process s_reg; end Clock_behave; ----------------- CLOCK_end ------------------- -------------- Ping Pong_start ------------------- library ieee; use ieee.std_logic_1164.all; entity Ping_Pong is port( Start, Lb, Rb, CLK : in std_logic; a,b,c,d,e,f,g,h : out std_logic ); end Ping_Pong; architecture Pong_Behave of Ping_Pong is type state is (wait_s, stopr_s, stopl_s, runr_s, runl_s); signal pres_s, next_s : state; signal count : integer range 0 to 10000000 :=0; begin State_Logic: process(CLK, start, Lb, Rb ) begin if(start = '0') then pres_s <= wait_s; elsif(rising_edge(CLK)) then count <= count +1; case pres_s is when wait_s => next_s <= stopr_s; count <= 0; when stopr_s => if (Lb = '1' OR Rb = '1')then next_s <= stopr_s; count <= 0; else if (count = 12)then next_s <= runl_s; count <= 0; else next_s <= stopr_s; end if; end if; when runl_s => if (Lb = '1' OR Rb = '1')then next_s <= stopr_s; count <= 0; else if (count = 72)then next_s <= stopl_s; count <= 0; else next_s <= runl_s; end if; end if; when stopl_s => if (Rb = '1')then next_s <= stopr_s; count <= 0; elsif (Lb = '1')then next_s <= stopl_s; count <= 0; else if (count = 12)then next_s <= runr_s; count <= 0; else next_s <= stopl_s; end if; end if; when runr_s => if (Lb = '1' OR Rb = '1')then next_s <= stopr_s; count <= 0; else if (count = 72)then next_s <= stopr_s; count <= 0; else next_s <= runr_s; end if; end if; when others => next_s <= wait_s; end case; pres_s <= next_s; end if;--start = 0 end process State_Logic; output_logic: process (pres_s,count) begin case pres_s is when wait_s => a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; when stopr_s => a <= '1'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; when runl_s => if (count = 0) then a <= '0'; b <= '1'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; end if; if (count = 12) then a <= '0'; b <= '0'; c <= '1'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; end if; if (count = 24) then a <= '0'; b <= '0'; c <= '0'; d <= '1'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; end if; if (count = 36) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '1'; f <= '0'; g <= '0'; h <= '0'; end if; if (count = 48) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '1'; g <= '0'; h <= '0'; end if; if (count = 60) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '1'; h <= '0'; end if; if (count = 72) then a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '1'; end if; when stopl_s => a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '1'; when runr_s => if (count = 0) then h <= '0'; g <= '1'; f <= '0'; e <= '0'; d <= '0'; c <= '0'; b <= '0'; a <= '0'; end if; if (count = 12) then h <= '0'; g <= '0'; f <= '1'; e <= '0'; d <= '0'; c <= '0'; b <= '0'; a <= '0'; end if; if (count = 24) then h <= '0'; g <= '0'; f <= '0'; e <= '1'; d <= '0'; c <= '0'; b <= '0'; a <= '0'; end if; if (count = 36) then h <= '0'; g <= '0'; f <= '0'; e <= '0'; d <= '1'; c <= '0'; b <= '0'; a <= '0'; end if; if (count = 48) then h <= '0'; g <= '0'; f <= '0'; e <= '0'; d <= '0'; c <= '1'; b <= '0'; a <= '0'; end if; if (count = 60) then h <= '0'; g <= '0'; f <= '0'; e <= '0'; d <= '0'; c <= '0'; b <= '1'; a <= '0'; end if; if (count = 72) then h <= '0'; g <= '0'; f <= '0'; e <= '0'; d <= '0'; c <= '0'; b <= '0'; a <= '1'; end if; when others => a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; h <= '0'; end case; end process output_logic; -- end Pong_Behave; -------------- Ping Pong_end -------------------- Mark as New
Could someone please help me understand whats wrong?
