I have an input pin in my design that I am using to bring in an external clock signal. I created a very simple test case where my entire design consists of a single DFF, which I clock with the external signal I'm bringing in.
I am getting the following warning: "Warning: Node: ext_clk_sig was determined to be a clock but was found without an associated clock assignment." I tried marking the input pin as a clock in the assignment editor by adding an "assignment name" of "global signal" set to a value of "global clock". This assignment has its "enabled" field set to "yes". Apparently I need to do more to get the Quartus compiler to treat my clock signal as a clock. Timing is critical on this signal. What do I need to do to make it clear to quartus that this pin needs to be treated like a clock? I really hope I do not have to use one of the dedicated clock pins. I do not have access to these on my current hardware platform. LHLink Copied
for static timing analysis with TimeQuest, declare the clock in an .sdc file and add it to your project under Assignments > Settings > Timing/TimeQuest
