17252 Discussions
How to measure the clock cycles used in a program in quartus?
Hello
How to measure the clock cycles used in a program in quartus? or the latency time of the program.
Quartis doesn't run any programs. It compiles your code into a netlist.
sorry if I did not explain my problem well, I need to know which is the latency time or clock cycles it takes to execute each instruction of my design on the FPGA.
That sounds like you have created a processor. You should know the latency from the design, or from good simulation.
