17241 Discussions
How to read bits from input in VHDL?
Hi guys..
Can anyone tell me how to read bits from a signal? Let's say I have 16 bits input signal and it's called signal A. How do I read the first 4 bits of the input signal and compare it with signal B which is also 4 bits? Is this possible?
you can access any bits in A:
if A(3 downto 0) = B then
--etc
Thanks Tricky. It worked. =)
But how about if I want to read only 1 bit? Say, there's 01010101 and I want to read the 4th bit.
assuming A is declared something like:
A : in std_logic_vector(7 downto 0);
op <= A(3);
thank Tricky! this helped so much. :)
