Quartus 9.1 SP2
Altera DE1 If I program the board using JTAG works well, but if I program using the active serial programming EPCS4 programming is successful but when I turn off and turn on the switch does not work run. But if I use another project file everything works perfectly. What could be the problem?Link Copied
