17263 Discussions
How to reference a modport declared in generate block of interface?
Consider an interface defined as following code:
interface test_interface# ( parameter MODP_CNT = 3 ); wire portsig_array; genvar iport; generate for (iport = 0; iport < MODP_CNT; iport++) begin:MODPORT_GEN wire portsig = portsig_array; modport testport(output portsig); end endgenerate endinterface
When I want to reference the modport 'testport' defined above in a module port list, how to write the port list in target module?
