17252 Discussions
How to report Tco, Tsu, Th of a derived clock or PLL clock?
Contributeur émérite II
1 311 Visites
I am using a EP2C8 device and using classic timing analysiser to check the timing relationship of my design. I used a PLL and used the PLL output as a global clock. How can I obtain the Tco, Tsu and Th related to the PLL output clock? Quartus only report these parameter related to the PLL input clock.
PLL input: 65.536M
PLL output 1: 51.2M, use as FPGA global clock
PLL output 2: 51.2M, output from PLL output pin to drive external device(SDRAM)
I want to adjust the phase relationship between PLL output 1 and PLL output 2. I can not use 51.2M clock chip directly because I had to use 65.536M clock to drive another device.
best, regard
0 Compliments
0 Réponses
Répondre
