I am ryt now working with coverage. I would like to know how to see detailed uncovered and covered bins in coverage?? Thanks in advance......:) i am using "vcover report -html -htmldir cov cover.ucdb"but it is not giving detail reprot it jst shows how many % coverage is..... so please tell me the command of anyone knows for the detail coverage report..............Link Copied
Hi daisyf,
Which tool r u using for simulation......? regards, dreku- Mark as New
Hello sir,
I m using vcover command so it means i am using Questasim tool.... 6.6f version.... So please help me. I want to see detail coverage. means which bins are covered and which are remaining...... I will be very thankful to you.. Please sir share your knowledge with me if you know... Thanks, Daisy:)- Mark as New
Got the solution.tHIS DETAILED FUNCTIONAL COVERAGE OPTION IS NOT SUPPOTER IN QUESTASIM 6.6F. YOU HAVE TO USE 10.0 PLUS VERSION.
Great....
Cheers :) dreku- Mark as New
In Questa 6.6 you need to set the option.per_instance = 1; of each covergroup in order to see individual bins. This only works well if there is only one instance of the class with an embedded covergroup.
after creating .ucdb file go to consol(cmd) and type following command
vcover report -details -html result.ucdb
Topic Options
