17254 Discussions
How to see the critical path of the design?
After the design is fully compiled, there is a parameter in different corner mode that is fmax. As my understand, this value depends on the length of critical path in the design. If the critical path is too long, where there are too many logic between two registers, the fmax will be low. I don't know whether my understanding is right. If it is, how can I check the critical path of the design and try to shorten it? If it isn't, anybody can explain and usually how to increase the fmax?
Why in fast 1200Mv 0c model, there is not Fmax report?
Thanks very much.
You should use Timequest to find this information. Specify your timing requirements and which clock frequencies you must use in your design, and any path that is too long to fit your requirements will end up in the "Top failing paths" report.
AFAIK Timequest gives a Fmax for all 3 timing models used.
--- Quote Start ---
--- Quote End ---
Thanks. I got it. Sometimes, when I read the fmax, the report posts several clocks in my
design with different fmax. What is mean of that?
If you have several clocks in your design, each one is analysed by Timequest, and the maximum possible value is given for each one of them.
--- Quote Start ---
--- Quote End ---
So that means there is a critical path for each clock. I just realize that I can check the critical path if it fails to meet time requirements in "Top failing paths" report. But if my design meet time requirement, but I still want to find where the critical path is, what should I do?
Thanks very much.
Just look at slack figures. The smallest slack is the critical path.
--- Quote Start ---
--- Quote End ---
Thanks very much, kaz.
