17254 Discussions
Verilog design and RTL viewer (Quartus II 8.1)
Hi everyboy,
I am not used with verilog (telling the truth I'm not used in design in general :P ) and I have a question... I don't understand why some register i shown on the right and only one on the left in this simple counter
module counter (data, count, rco, load, enable, reset, clock); parameter WIDTH=4; input data; input load, enable, reset, clock; output count; output rco; wire data; wire rco, load, enable, reset, clock; reg count; assign rco = count == {WIDTH{1'b1}} ? 1'b1 : 1'b0; always @ (posedge clock) begin if (!reset) count <= 0; else if (enable) begin if (load) count <= data; else count <= count + 1'b1; end end endmodule
There is a screenshot of RTL viewer.
img840.imageshack.us/img840/196/countera.jpg
(sorry i cant post as image ... forumm need 5 post :( )
Is there a problem? Some options are wrong? I use Quartus 8.1 because i like the integreted simulator, from version 9 there isn't right?
Thanks a lot in advance,
Alessandro Vincenzi
The block placement in RTL and gate level netlists is arbitrary and doesn't have a particular meaning. Everything looks correct in your design.
Thank you very much, you were very clear.
that's all because the damn synthesizer modifies your code and creates different circuit.new circuit will have same functionality. but it makes much harder to track down which variable became which element in RTL.
