17241 Discussions
How to synthesize a CPU with a FSM behavioral module
Hi all,
I'm new in Verilog and FPGA design.
I write a code to implement simple ALU and Memories to do simple STORE and ADD operation.
After compilation, the tool reports that Clock Hold not operational because
the clock Skew>Data Delay. And there are also some warnings that latches are inferred.
I am wondering is there something wrong with my code? For my CPU, there is only one general purpose register AC(accumulator). MA is the address register and MD is the data register. IA, IB are index registers, which are not used in this case.
In the state3 of my FSM,if it's indirect addressing mode, I think I am trying to write values to AC, MA and MD twice in one clock cycle. Will that cause problems?
If anyone can help, thanks a lot...
module CPU1(clk,reset,AC); input clk,reset; output AC; reg MEM; reg CF; reg PC,MA,IA,IB; reg MD,AC,IR; reg state,nextstate; parameter state0=2'b00, state1=2'b01, state2=2'b10, state3=2'b11, DIRECT=2'b00, INDIRECT=2'b01, INDEXED=2'b10, OTHER=2'b11, LOAD=3'b000, ADD=3'b001; initial begin PC=0; IR=0; MEM=000_00_0000000000100; //Load M into AC MEM=001_00_0000000000011; //Add M to AC MEM=000_00_0000000000000; //DOES NOTHING MEM=000000000000001100; //DATA MEM=000000000000000010; //DATA end always@(*) case(state) state0:begin nextstate=state1; MA=PC; PC=PC+1; end state1:begin nextstate=state2; MD=MEM; end state2:begin nextstate=state3; IR=MD; end state3:begin case(IR) LOAD:begin case(IR) DIRECT:begin MA=IR; MD=MEM; AC=MD; end INDIRECT:begin MA=IR; MD=MEM; AC=MD; MA=AC; MD=MEM; AC=MD; end INDEXED:; OTHER:; endcase end ADD:begin case(IR) DIRECT:begin MA=IR; MD=MEM; AC=AC+MD; end INDIRECT:begin MA=IR; MD=MEM; MA=MD; MD=MEM; AC=AC+MD; end INDEXED:; OTHER:; endcase end default:begin case(IR) DIRECT:begin MA=IR; MD=MEM; AC=AC+MD; end INDIRECT:begin MA=IR; MD=MEM; MA=MD; MD=MEM; AC=AC+MD; end INDEXED:; OTHER:; endcase end endcase end default:begin nextstate<=state0; end endcase always@(posedge clk) if(~reset) state<=state0; else state<=nextstate; endmodule
Do you have outputs?
As far as I know every digital module (in fact any system) is based on having inputs and outputs. The functionality decides outputs based on inputs and internal states. I know some may not have explicit input e.g. oscillators but still have input...
edit: only exception is testbench (simulator tools)
kaz,
I added the accumulator as the output. But I met another problem.
I could not find the values of M in simulation.
Are we able to download data to Memory on FPGA with verilog inital block as I did in this case?
What do you do to these M values? do they affect the output?
Compilers are designed (by software people) to remove any logic that does not affect the outputs because it is seen as useless waste of logic and will affect the reputation of their devices so be kind to them.
I believe your state3 does not move any further. Thus your FSM starts st state0 and moves to state3 and stops there. As a result M value stays zero.
kaz,
the synthesis tool reports clock hold not operational due to Clock Skew>Data Delay in the compilation report.
Do you know how to fix this:(
thanks.
clock skew is a repeated scenario for many beginners and has been addressed in several threads.
In FPGAs (as opposed to ASICs) the designer must use the clock network (dedicated clock pins and routing). As such the fitter takes care of tSU of all internal registers by restricting fmax and takes care of tH by making sure that clock arrives at latching register not delayed with respect to data.
If the designer opted for gating the clock then clock may be delayed more than data and the fitter cries in despair. So if you have to gate the clock make sure you put it back to rest on global routing. I don't normally gate my clocks at all. If I have to then I use altera's clock mux to bridge over. You can also use settings in quartus or HDL attributes to reconnect.
