17261 Discussions
How to use VHDL to write a kind of LED light program?
How to make an LED light by writing VHDL code program? i am just leanning VHDL.thank you !
It is very easy. Refer to below:
library IEEE;
use IEEE.std_logic_1164.all;
Entity LED_light is
port ( LED_out : out std_logic);
end LED_light;
Architechture RTL of LED_light is
begin
LED <= '1';
end RTL;
library IEEE;
Entity LED_light is
end LED_light;
architecture RTL of LED_light is
begin
LED_out<= '1';
end RTL;
--- Quote Start ---
library IEEE;
Entity LED_light is
end LED_light;
begin
LED <= '1';
end RTL;
--- Quote End ---
Do u know how to control the brightness of the output LED in Quartus 2?.
Ex. OFF (Stage1)>Dim (Stage2)>Full brightness (Stage3). I just need the logic, no need to type the full code here. Any help would be appreciated.
Anish
Yes it is easy, just google for PWM verilog, or PWM VHDL.
interesting. I thought only PIC can do this.
