Hi, all
I am doing a traffic light controller project with using DE2 board... the code I have is compiled perfectly, but when I use the DE2 board, it doesn't work properly... Some lights should be turned on when I switch on.. but for some reason it keeps having the same issues although I try on and on. So I asked the professor about the issue, and he said this is logic problem... I hope you help me out. Here is the code.library IEEE;
use IEEE.std_logic_1164.all;
--use IEEE.std_logic_arith.all;
use IEEE.std_logic_unsigned.all;
entity traffic_light_controller is
port (
CLK: in STD_LOGIC;
CLR: in STD_LOGIC;
LIGHTS: out STD_LOGIC_VECTOR (5 downto 0));
end traffic_light_controller;
architecture traffic_light_controller_arch of traffic_light_controller is
type traffic_light_controller_type is (GR, RY, RR2, YR, RG, RR1); --G=green R= red Y=yellow, GR is the first statement, when Green is turned on at northwest, Red is turned on eastwest, and RR1 which is Red and Red for the first time and RR2 for the second time.
signal traffic_light_controller: traffic_light_controller_type;
signal Count: STD_LOGIC_VECTOR (3 downto 0);
constant sec_1: STD_LOGIC_VECTOR (3 downto 0) := "1111";
constant sec_5: STD_LOGIC_VECTOR (3 downto 0) := "0011";
-- diagram signals declarations
-- SYMBOLIC ENCODED state machine: traffic_light_controller
-- attribute enum_encoding of traffic_light_controller_type: type is ... -- enum_encoding attribute is not supported for symbolic encoding
begin
-- Machine: traffic_light_controller
traffic_light_controller_machine: process (CLK,CLR)
begin
if CLR='1' then
traffic_light_controller <= GR;
-- Set default values for outputs, signals and variables
Count <= X"0"; --count is set to zero
elsif CLK'event and CLK = '1' then
case traffic_light_controller is
when GR =>
if count < sec_5 then
count <= Count+1;
else
traffic_light_controller <= YR;
count<=X"0"; --count is reset to zero
end if;
when YR =>
if Count<sec_1 then
Count <= count+1;
else
traffic_light_controller<=RR1;
count<=X"0";
end if;
when RR1 =>
if Count<sec_1 then
traffic_light_controller <= RR1;
Count <= count+1;
else
traffic_light_controller <= RG;
end if;
when RG =>
if count<sec_5 then
count<=count+1;
else
traffic_light_controller <= RY;
count<=X"0";
end if;
when RY =>
if count<sec_1 then
count<=count+1;
else
traffic_light_controller <= RR2;
count<=X"0";
end if;
when RR2 =>
if count<sec_1 then
count<=count+1;
else
count<=X"0";
end if;
--vhdl_cover_off
when others =>
--vhdl_cover_on
end case;
end if;
end process;
--C2: process(traffic_light_controller)
--begin
--case traffic_light_controller is
--when GR => lights <= "100001";
--when YR => lights <= "100010";
--when RR1 => lights <= "100100";
--when RG => lights <= "001100";
--when RY => lights <= "010100";
--when RR2 => lights <= "100100";
--when others => lights <= "100001";
--end case;
--end process;
--end traffic_light_controller_arch;
--signal assignment statements for combinatorial outputs
LIGHTS_assignment:
LIGHTS <= "100001" when (traffic_light_controller = GR) else
"010100" when (traffic_light_controller = RY) else
"100100" when (traffic_light_controller = RR2) else
"100010" when (traffic_light_controller = YR) else
"001100" when (traffic_light_controller = RG) else
"100100" when (traffic_light_controller = RR1) else
"100001";
It probably is a logic problem
Have you simulated it? where's the testbench code?- Mark as New
What's the exact problem? No light turns on or they simply don't turn on in the wanted way?
In the first case I'd consider pin assignment. In the second one it's the logic. In particular I think the sec_1 definition is not correct. This one would lead to more common traffic light behavior: sec_1: STD_LOGIC_VECTOR (3 downto 0) := "0000";- Mark as New
We have something similar for the upcoming project. Interesting !!!
