17258 Discussions
Hunting down a stuck port?
Anybody have suggestions for why a port might be stuck?
I can see in the RTL viewer that Quartus has replaced my inputs with 0. However, I don't know why. Everything up to that block is fine in the RTL viewer. The block in question is included below.
The lookup table files exist and are non-zero. This block simulates just fine in both modes outside of Quartus (I don't really simulate Verilog in Quartus if I can help it). So, I'm really confused as to why suddenly Quartus thinks that theta is constant inside this block.
Right now I'm trying to peel out a testcase that shows it without having to compile the universe.
module my_sincos_lut(/*AUTOARG*/ // Outputs sin_out, cos_out, // Inputs theta, gclk ); output signed sin_out; output signed cos_out; input signed theta; input gclk; /*AUTOWIRE*/ /*AUTOREG*/ // Beginning of automatic regs (for this module's undeclared outputs) reg signed cos_out; reg signed sin_out; // End of automatics reg signed sin_rom; reg signed cos_rom; wire theta_unsigned = theta; initial begin $readmemb("my_lut_sin.txt", sin_rom, 0, 8191); $readmemb("my_lut_cos.txt", cos_rom, 0, 8191); end `ifndef MY_LUT_CLOCKED always @(theta_unsigned) begin sin_out <= sin_rom; cos_out <= cos_rom; end `else always @(posedge gclk) begin sin_out <= sin_rom; cos_out <= cos_rom; end `endif endmodule // my_sincos_lut
